Author Topic: Kenwood TH-21AT battery pack rebuild  (Read 1431 times)
W8EXX
« on: August 29, 2010, 05:37:42 AM »
Can anyone tell me how to open the PB-21 battery pack for the TH-21AT handheld without damaging it in order to install a new insert?
Thanks, Glenn W8EXX
KL0S
« Reply #1 on: August 29, 2010, 02:34:21 PM »
Glen - I just looked at the two battery packs for my TH-21AT and my little note said I rebuilt them way back in 1998! As far as I can remember, and looking at how I glued them back together, you have to separate the interior plate from the pack by using a sharp razor blade/box cutter to pry the pieces carefully apart. Use the blade to slowly and repetitively cut thru the space between those pieces at the top and bottom of the pack....it can be done, just take your time. Once you've replaced the nicads simply hot glue the assembly back together so it won't be so difficult in the future. GL!
Dino KL0S
KF6QEX
« Reply #2 on: August 31, 2010, 03:19:57 AM »
Battery rebuild eham article http://www.eham.net/articles/17840
W8EXX
« Reply #3 on: September 02, 2010, 07:07:57 AM »
Thanks for the replies.  The battery case opened with no damage.
Glenn W8EXX
