Author Topic: best CW encoder/decoder?  (Read 2005 times)
KB1IUI
« on: May 16, 2009, 07:16:39 AM »
I have some  medical problems and haven't been able to do code. I really want to do QRP CW. Which are the best programs for encoding/decoding CW by computer, both pay and freeware.
Mike
NA4IT
« Reply #1 on: May 16, 2009, 04:22:03 PM »
There are a lot of the digital sound card programs that will do CW. However, most programs only decode proportionately to how well the sender sends on the other end of the QSO. They are using algorithms that look for perfectly spaced dits and dahs that are exact lengths.
That said, you should able to communicate with another keyboard operator well. And, for those with problems hearing code, I don't see why there aren't some CW frequencies where folks operate keyboard.
de NA4IT
W5DQ
« Reply #2 on: May 20, 2009, 10:56:39 AM »
I have found that MixW has a very efficient CW interface. It will decode about 90% of the CW it hears accurately. Like was said, it depends alot on the sender's fist and RX conditions. You have to tweak it but I have mine finally to a point where it will pick out even the weak signals pretty accurately.
Gene W5DQ
Gene W5DQ
Ridgecrest, CA - DM15dp
www.radioroom.org
W0GLB
« Reply #3 on: May 22, 2009, 08:05:54 AM »
I can strongly recommend both the CWGet and CWType combo, and HRD/DM780.  I have used both, and both are very good at what they do, and very simple to use.  My only concern is that no computer program is ever going to approach the performance level of the human ear/brain combo when it comes to interpreting a signal that is barely perceptible through the noise. I only raise this issue as you said you were interested in QRP-and the essence of QRP is pulling out the weak signals.  That said, I am quite confident that, if you are running 5-100w into any reasonable antenna, you will have plenty of stations to work using either software combo.
73 es GL,
W0GLB Gordon
W0BTU
« Reply #4 on: June 27, 2009, 12:53:05 PM »
I don't own this program, but it sounds capable of the job.
http://www.dxatlas.com/CwSkimmer/
http://k9jy.com/blog/2008/03/04/cw-skimmer-a-monster-or-killer-tool/
73 Mike
G4AON
« Reply #5 on: June 28, 2009, 04:44:53 AM »
Sending CW with a keyboard is easy, provided you remember to use appropriate abbreviations rather than typing out long words, etc. Common examples might be sending "R TU = 73 GN" which is fairly typical of a CW operator on a key but probably isn't how most of us would send a message on a keyboard.
The computer decoders work well with clear signals and keyboard senders, but 95% of the time you won't be listening to "perfect" senders or signals. Code that is easy to understand by ear ends up not being decoded perfectly by a computer... I have an Elecraft K3 which has built in decoding for CW, it reproduces the errors exactly as they are sent. I know what the word should be and ignore the error without really thinking about it... The kind of errors I am referring to are mostly marginally wrong spacings, which result in "N" printing as "TE", or "IT" as "A".
You will find PSK31, and similar modes, work a whole lot better than computer decoded CW. The decoders suggested by others will work, but not as well as a MK 1 ear.
73 Dave
