Author Topic: Zero Beat TS-430SAT  (Read 2278 times)
K3ZL
« on: October 10, 2010, 07:32:04 PM »
With the Kenwood TS-430S zero beat is accomplished by matching the tone of the station I want to work at the same pitch as the built in side tone.  At my age, it is difficult to do that quickly, as I am getting more tone deaf.  I have turned up the volume of the side tone, which helps, but my question is:  Is there a modification or some after market product that I can use to help with zero beating signals easier?  Something that uses an LED light for example.
N4IAG
« Reply #1 on: October 11, 2010, 05:39:29 AM »
There is a kit sold that may work: http://wb9kzy.com/zerobeat.htm
Also if you use the radio next to a computer, cw software like CW Get has a feature to visually zero beat the received signal to your sidetone.
K3ZL
« Reply #2 on: October 16, 2010, 09:00:37 PM »
Tnx, N4IAG.   I ordered the kit from Chuck last night.  Just what I was looking for.
Tnx, K3ZL
N3HAM
« Reply #3 on: October 21, 2010, 06:46:45 AM »
I have two 430s. You can try using the 500 hz filter to get close. Listen for your contact in the passband. It works for me.
KB4MB
« Reply #4 on: October 22, 2010, 07:23:51 AM »
Can you do the normal trick of switching to sideband, making the signal disappear, then switch back to CW to have a perfect zero beat?  Easier on the 430 since you have seperate mode switches unlike most rigs now which just have 1 mode switch...
AL7MM
« Reply #5 on: October 28, 2010, 05:19:43 PM »
What I do is to set my RIT to 800hz and zero beat that.
Mike, KL7MJ
K3ZL
« Reply #6 on: October 28, 2010, 05:47:58 PM »
Mike, KL7MJ
Mike, give me that procedure again;  Do you mean zero with main tuning, then set RIT to 800hz?   Also, is that + or - hz?
thanks, KC
K3ZL
« Reply #7 on: October 28, 2010, 05:53:09 PM »
Kris, that sounds simple enough. Does that really work?  Reminds me of when I was a novice using seperate TX and RX...zero beating was a snap.  Tnx for this tip.  KC
AL7MM
« Reply #8 on: November 01, 2010, 09:13:25 PM »
KC -
I set my RIT for +800hz for 20m, probably need to set it for -800hz on 30m and below.
Mike, KL7MJ
K3ZL
« Reply #9 on: November 03, 2010, 07:13:06 PM »
KC -
Mike, KL7MJ
Awesome, Mike.  Tnx!
