Author Topic: Icom CS-T90A won't write to IC-E90  (Read 4966 times)
GW0DIV
« on: October 28, 2010, 01:48:46 PM »
I'm trying to fill up the memories on my IC-E90 using CS-T90A, I can read from the radio and edit the memories, but can't write the new data to the radio. I get a "no answer from transceiver" message. Funny thing is it all worked OK when I first used it ages ago when I first used it, but now same software, 2 different leads and 3 computers all give the same result. Has anyone else had this? I could probably do with a copy of the manual or some setting ideas for the com ports. Perhaps I just need a memory upgrade of my own!!
Rhys
GW0DIV
GW0DIV
« Reply #1 on: December 08, 2010, 10:17:10 AM »
Sorted it!! I was puting the radio into cloning mode, for once it was R'ing the FM that caused the problem!!
Rhys
GW0DIV
DM7CI
« Reply #2 on: January 10, 2014, 04:10:03 AM »
Hello Rhys,
I have the same problem, trying to programm my ic-e90. Could you describe more in depth how you solved it?
73 dm7ci
BG4LA
« Reply #3 on: March 12, 2014, 08:02:03 AM »
do u check ur cable?
PH0MB
« Reply #4 on: July 06, 2015, 02:25:49 PM »
sorry for resurrecting an old thread
I was having the same issue. I was able to write the data a few years agoo, but somehow it did not work any more so it seems.
I was able to read stuff , but writing it back failed miserably every time.
I was suspecting the interface or cable was bad somehow, but it seems to be the clone mode SET/MR PWR three finger salute for getting into clone mode must be aborted before writing back.
So: writing back does _not_ work in Clone mode only in normal operation mode.
The write action sets the IC-E90 T90-A into CI mode and after finishing it ends into clone mode.
It's not very clear in the manual and in the software online help, and I seem to have forgotten that fact from the last time I used it.
I'm happy now getting it working again. the software is _ahem_ well, it works, but it's not very user friendly and badly documented.
