Author Topic: 12-Meter Question  (Read 4745 times)
K3CXG
« on: November 03, 2010, 06:54:06 AM »
I recently picked up an IC-706 MK II.  I have an old unmodified Rat Shack mobile CB antenna that I use for 10 and 6.  It's base loaded, with a whip that's about three feet long.  My question is, can I add a few inches of wire to the top to use it as a quick-and-dirty 12 meter antenna, and if so, how many inches?  I don't currently own or have access to an SWR meter or antenna analyzer, so if anyone has a reasonable guess, I'd love to see it here.  I'll be getting an actual 12-meter whip at some point, but I'd like to get on now, if I can.
Thanks
Mike K3CXG
« Reply #1 on: November 03, 2010, 07:04:16 AM »
To answer the question you'd have to know a bit more than you do. Like the reactance of the inductor. You could calculate it, and perhaps come close. But in the end, it is still going to be a cut and try.
W5DXP
« Reply #2 on: November 03, 2010, 08:18:30 AM »
... can I add a few inches of wire to the top to use it as a quick-and-dirty 12 meter antenna, and if so, how many inches?
A quick and dirty simulation with EZNEC says that adding ~7 inches should shift the resonant frequency from 27 MHz to 25 MHz assuming the base-loading coil is a constant inductance.
73, Cecil, w5dxp.com
« Last Edit: November 04, 2010, 11:04:42 AM by Cecil A. Moore » Logged
K3CXG
« Reply #3 on: November 03, 2010, 11:29:18 AM »
Alan and Cecil, thank you very much for your input.  I'll try seven inches; if that's not it, I'll try slightly longer and/or shorter to see what may develop.
Mike K3CXG
W5DXP
« Reply #4 on: November 04, 2010, 04:31:28 AM »
The seven inch estimate is based on the base-loaded three foot whip being resonant on 27 MHz.
K8KAS
« Reply #5 on: November 09, 2010, 09:06:32 AM »
I have never seen a IC706 without a SWR bridge , its under M3--"meter"  and just punch up SWR and you will see it displayed. It should be simple to add or whatever to your old CB antenna. You can use a small hose clamp to add the needed wire, I would think 3 to 5 inches would do it.
Denny K8KAS 73
KD4LLA
« Reply #6 on: November 09, 2010, 03:40:42 PM »
Call me stupid, but I would never trust the SWR meter in my IC-706 trying out an adjusted old CB antenna.  I am not saying I wouldn't use the antenna, I would just find a meter or analyzer first.  After the radio, the next most important thing is the antenna.
W5WSS
« Reply #7 on: November 12, 2010, 12:25:05 PM »
One can add a small hub of spokes and attach with a SS hose clamp. The empirical method is satisfactory since pre modeling is not perfect yet. I have used several different methods of adding length to a mobile antenna to serve a temporary need. I used an electrical barrel splice crimped and soldered the the copper wire spokes sloped downward, and stripped the insulation off then SS hose clamped it to the tip of the mobile whip it required a little tweaking but alas tuned nicely. I suggest the crimp and soldering after the final adjustments are made have fun.
« Reply #8 on: November 12, 2010, 03:35:06 PM »
I've also added a temporary horizontal extension wire (single spoke) with an alligator clip.  In fact for one
antenna the alligator clip alone was all I needed to get it to tune.  At least it makes it easy to get started.
KC9QPF
« Reply #9 on: November 30, 2010, 02:25:28 PM »
K3CXG: If you have an unmodified CB antenna, how are you using it on 6M and 10M? How do you know what your SWR is on those bands if you don't have an SWR meter? I'd bet that it's far out of an acceptable range.
« Reply #10 on: November 30, 2010, 03:08:41 PM »
A 12 meter Hamstick ($30.95 at HRO) is a good and inexpensive 12 meter mobile antenna.
K3CXG
« Reply #11 on: December 02, 2010, 08:43:37 AM »
KC9QPF:  You're right.  I misspoke - I use the CB antenna on 10; however, I use the 5/8-wave 2M antenna on 6, as it approximates a 1/4 wave on 6. My bad.  I typically have both antennas on the car, hence the momentary confusion.
WX7G:  I am indeed planning to get a hamstick.  Just wanted something to tide me over until I get there.
Thanks again to all who have offered their help!
73, Mike K3CXG
NK5G
« Reply #12 on: December 03, 2010, 12:35:53 PM »
I use the Hustler coils with the MO-4 mount. Works FB.
