You might consider a Cushcraft 13B2 2m antenna and just take it into your garage and hang it from the ceiling is one option I started with
That is another good tip, I will check out Cushcraft. Meanwhile, I went back to the M2 site and looked over the 2M products. The 2MCP14 is circular polarized 7 element (each) on 10.6' boom with 10.2 db gain. At first I thought circular polarization would be an advantage to overcome Faraday polarization effects. Then I looked deeper and learned that then I have to worry about right hand vs left hand circular polarization, one preferred for transmitting, the other for receiving. Then I got lost since I could not change the handedness so this antenna would not seem to work with just one. I would need two, one for receiving, the other for transmitting.
So, do I understand this correctly? For a single Yagi EME station, circular polarization does not seem to be an option because of the required left-right handedness between transmit and receive? Or, am I over reacting?
