Author Topic: Yaesu FT-450 dead  (Read 15217 times)
KK4AZ
« on: November 27, 2010, 12:30:37 PM »
I just purchased a used FT-450. When pushing the on putton I only hear a click. Holding longer creates a string of clicking. Sounds just like the clatter of a relay clicking in an out. Any ideas of what would cause this. Like, in transit ?  Huh
   Tnx fer any help. Ken ks4nu
NO2A
« Reply #1 on: November 27, 2010, 02:36:07 PM »
By all means i would do a full reset to see if this clears it. Assuming of course the radio will do this. My FT-857D has a way of cleaning the relay by holding in certain buttons then holding the power button. Maybe doing this would help yours,provided it will do it in the condition it`s in(if  the `450 has this feature,that is). Check your manuel first,or other `450 owner`s.
VE3OYJ
« Reply #2 on: November 29, 2010, 11:50:43 AM »
Check for power supply voltage at radio.
Sounds like low voltage not allowing the relays to be pulled closed.
KK4AZ
« Reply #3 on: December 02, 2010, 03:28:07 PM »
I tested the pwr supply wid 2 meters. Both showed 13.8v. The digital meter didn't show a drop (too slow) but the analog meter needle dipped for a nano sec. (the widge of the needle) then back on the mark when the relay clicked. Connections at rig looked  Huh good so only ckd at the pwr supply.
   I gave up an sent the rig to  http://www.hamradiorepairfix.com/ also known as Technical Specialists, LLC
 Will let ya know outcome. tnx, Ken ks4nu
KD4LLA
« Reply #4 on: December 05, 2010, 12:45:24 PM »
Ken,
Sorry to hear you are having trouble w/ the FT-450.  Not much to offer bit I remember you as KD4IAJ.  Retired to Florida?  Well I am in Minnesota near my brothers farm.  Anyway, send me a note later if you want.
Mike
KD4LLA
m3425man@yahoo.com
WV4I
« Reply #5 on: December 07, 2010, 07:45:29 AM »
See this radio already went for repairs.
Meanwhile, first want to unhook everything except power cable. Carefully check for cable flaws. Everything includes mike, antenna, everything. These radios have a substantial amp draw at power up. and if amps/volts not there, click-clack, perhaps momentary display, and shutdown. Try starting one up with a 12vdc/1A supply for a demo.
Next, want check position of the programming switch. See bottom, front left corner, of radio. For normal ops, this switch should be to Left, and for programming, right. Yaesu has instructions, pics, on their web site, re this switch. Their right/left instructions are confusing vs orientation of the radio. Follow instructions exactly, as it matters whether/when power is supplied to radio, plugged in, whether turned on or not. And sometimes these radios hang up during attempts to install updated firmware, not to mention attempts to soft program freq expansion, etc.. So try turn on with switch in both positions, hopefully will get control of radio back, if not simply a power supply/quality problem. Also, could be dealing with a botched firmware upgrade.
Very early FT-450AT owner here, and still have it/like it.
KA1VF
« Reply #6 on: March 01, 2011, 12:53:21 PM »
I'm the original owner of an "old" Yaesu FT-450AT rig manufactured April of 1997,
and I've had this same problem while connected to a dedicated RadioShack PS-25.
It happened the first time just a few days after I'd purchased it at HRO, and they
gave me a new replacement DC cord, but I still have that problem occasionally.
   note: I've always been able to get the rig to eventually power up by wiggling
           and jiggling the DC cord's connector at the back of the radio. Also, I've
           occasionally had to manually tighten down the DC cord's connections at
           the back of the RadioShack PS-25.
            good luck and 73,  Bob
K9RCM
« Reply #7 on: March 08, 2011, 12:25:24 PM »
I think maybe you mean 2007 not 1997, heh?
KA1VF
« Reply #8 on: March 17, 2011, 07:22:55 AM »
   Yes, I was having a "Senior" moment, and I meant to type April of 2007.
        73 to all, de KA1VF
PE1HZG
« Reply #9 on: March 29, 2011, 11:18:25 AM »
An 897 (and, I suspect, the 450, since it may share some of the design), draws a sizable power surge if powered up. I have had lab power supplies go into current protection because of this.
Also, a poor connection in the power cord may cause the voltage to drop, causing the CPU to shut down, then restart, etc.
Test with a power supply with more reserve, or a car battary, and check the power cable wiring.
Geert Jan PE1HZG
KB9HGI
« Reply #10 on: March 31, 2011, 08:50:34 PM »
Where is there a switch in the bottom left corner? I have a Yaeu FT-450At 2007 model and I do not see a program switch on the fron left bottom corner. You sure you have the right radio?
KG6BRG
« Reply #11 on: April 10, 2011, 06:11:29 AM »
[/quote]
You have to remove the bottom cover, if I remember correctly.  I've seen it (the switch) when I was installing the flip up feet.  cheers.
N0OHL
« Reply #12 on: October 28, 2017, 05:57:52 AM »
Have same problem -- checked by Astron Power supply- it is at 13.8 volts.   Plugged in my old Pyramid Power Supply with the variable voltage dial.  Moved the voltage up to 14.5 and Radio turned on.   Before it was just clicking, and I couldn't do a reset because it just clicked.  Measured no-load voltage at radio.  I do have a long ( 5 foot ) power cord with fuses and two sets of Power Poles used to connect it -- so maybe losing voltage....
Anyway I think I will get a short wire and just a connector and try that -- will re-post result...
Chuck n0ohl
N0OHL
« Reply #13 on: October 30, 2017, 07:31:06 PM »
Well, the higher voltage was just a temp fix...  Does not start reliably at higher voltage now.  After about 10 times trying it does start.  Haven't tried the new wire yet.   More later
