Author Topic: Drake W4 wattmeter problem  (Read 3731 times)
COMINGBACK
« on: December 14, 2010, 04:52:27 PM »
Purchased a W4 off of you know where.  Excellent shape physically, even has the inspection tag on it still.  However, DOA.   Meter movement is not stuck as it moves freely.   Where do I look first?
AD4U
« Reply #1 on: December 14, 2010, 05:55:15 PM »
Check to make sure the meter movement is not open.  Check the diodes.  Check for modifications or butchering.  Check the connecting cable between the ""sending unit" and the meter.
Dick  AD4U
K4DPK
« Reply #2 on: December 15, 2010, 08:34:36 PM »
Does the meter work in any range either fwd or reverse?  If not, the meter coil is probably open circuit.
Phil C. Sr.
k4dpk
KD0UN
« Reply #3 on: December 17, 2010, 10:35:11 AM »
My guess is that one of the wires is broken in the connecting cable either in the meter case or the in-line unit.   This would be the most obvious place to look initially.
If it was a diode problem, it would probably only be one, and that would only affect either forward or reverse.
COMINGBACK
« Reply #4 on: December 17, 2010, 07:12:16 PM »
Thanks everyone.  It does appear to be the gray connecting cable between the sensor unit and the meter.   When extended to operate "remotely," it seems to operate intermittently.
K4DPK
« Reply #5 on: December 24, 2010, 12:50:43 PM »
Any more info?  Did you fix it?
Phil C. Sr.
k4dpk
