Author Topic: Drawings of UHF connectors  (Read 4381 times)
KC5AOS
« on: December 27, 2010, 12:34:22 PM »
Does any one know where I can get drawings for PL-259 connectors?  UHF male and UHF female. . . etc.
K7KBN
« Reply #1 on: December 27, 2010, 03:07:55 PM »
Using Google Images, I found about seventeen bazillion pictures, drawings and such.
Pat K7KBN
CWO4 USNR Ret.
KC5AOS
« Reply #2 on: December 27, 2010, 07:34:42 PM »
 I checked both Yahoo and Google, nothing.  I don't suppose you could provide me with a link or a net file path.
Technical drawings are what I am after.
KE4DRN
« Reply #3 on: December 27, 2010, 07:35:29 PM »
hi Damon,
line drawings from AMP
http://www.amphenolconnex.com/products/uhf.asp
73 james
« Last Edit: December 27, 2010, 07:37:33 PM by James » Logged
K7KBN
« Reply #4 on: December 27, 2010, 09:33:49 PM »
Go to Google, select "images" and enter your search criteria - I think I used UHF CONNECTORS.
Pat K7KBN
CWO4 USNR Ret.
KC9Q
« Reply #5 on: December 27, 2010, 09:39:22 PM »
Damon,
Go to http://www.amphenolrf.com/search.asp?sid=4D1928807FDCE17F&N=57
Then select Customer Drawing on the right side menu from the connector you have in question.  This should give you the answer you need.
Mike, KC9Q
KC5AOS
« Reply #6 on: December 28, 2010, 09:57:42 AM »
Well, the drawings found on the Amphenol site were useless, could not read.  Either a bad scan or done on purpose.   You would think after 80 years or so, these drawings would not be hard to find.  However, I was able to download IGS/IGES files which I can open up in SolidWorks and get what I want.  That is just as good if not better.
The Google images were not useful.  No technical details.
Thanks all.  Keep the suggestions coming, I realy would like a PDF technical drawing.
Damon
KC5AOS
AD5X
« Reply #7 on: December 28, 2010, 01:24:53 PM »
Go to www.mouser.com.  Search on UHF Male and UHF Female.  Click on the data sheet for the connectors yu are interested in.
Phil - AD5X
KE4DRN
« Reply #8 on: December 28, 2010, 03:02:07 PM »
Hi Damon,
The drawings on the AMP site are in PDF,
what version of Adobe Reader are you using?
http://drawings.amphenolrf.com/Customer_Outline/C083-1SP-15RFX.pdf
Why would they have bad scans 'on purpose'?
Their business is connectors and we are customers.
If you don't see  what you need just ask them and they
will help you out.
http://www.amphenolrf.com/contactus.asp?N=0&sid=4D1928807134617F&
73 james
Damon
KC5AOS
« Last Edit: December 28, 2010, 03:07:01 PM by James » Logged
W3LK
« Reply #9 on: December 28, 2010, 03:33:55 PM »
FWIW, My browser (Safari) reads these just fine, as does my Mac's Preview application, and they print out OK, as well.
K2FOX
« Reply #10 on: December 29, 2010, 01:27:16 PM »
Same here, using Explorer 8 and Adobe 9, all files viewable/printable, perfectly clear.
K2YO
« Reply #11 on: January 03, 2011, 04:27:50 PM »
" ... or done on purpose"
Why would any company make their sales and technical unviewable on purpose?
Bernie
