Author Topic: Yaesu FT-101E regulator board repair  (Read 1511 times)
KD5FPO
« on: January 26, 2011, 02:40:31 PM »
I have an ft-101e with a bad 1314a regulator board, the problem is 13.6 volts in but no 6 volts out, pretty sure it's a bad MFC-6030 (Q4).  Anyone know of a good fix for this or a replacement for the outdated and discontinued mfc-6030?  Also is that component simply two transistors head to head? I can find no info. on the device.  I have two 2N9604s, would they work in place of the old component? Any help is appreciated, tnx. Michael KD5FPO@juno.com
KE4DRN
« Reply #1 on: January 26, 2011, 04:03:35 PM »
hi Michael,
take a look at the bottom of this link
http://www.foxtango.org/ft101/foxtangoft101module.htm
Try using a modern device to replace the obsolete part
http://www.national.com/ds/LM/LM117.pdf
73 james
« Last Edit: January 26, 2011, 04:11:39 PM by KE4DRN » Logged
N4ATS
« Reply #2 on: January 27, 2011, 05:37:01 AM »
I doubt it is bad , it is probably loaded (has a near short somewhere from another board) causing the VDC to go to 6V. I suggest touching it after it has been on a while and seeing if it gets warm.
If it is , then start removing the circuits attached to it one-by-one
Chances of that regulator going bad are null... Its current limited
KE4DRN
« Reply #3 on: January 30, 2011, 10:13:30 PM »
hi Bill,
He posted that it is bad, the newer question has the details.
http://www.eham.net/ehamforum/smf/index.php/topic,73158.0.html
73 james
