I just did a test that many may find interesting especially those wanting to be more "green". Using a old style Astron 20amp Linear supply and a Astron 30 amp switching supply I made the following observations. Also the test rig was a Kenwood TS-570 and transmitting FSK into a dummy load. Furthermore radio draws 1.45 amp on standby and 12.46 amps at 50 watts out and 17.4 amps at 100 watts out @13.8 volts.
RS20
Turned on no load: 18 watts total
With radio turned on low volume: 53 watts total
With radio transmitting 50 watts: 310 watts total
With radio transmitting 100 watts: 436 watts total
In summary, power supply draws 35 watts extra to power radio and 292 watts extra to transmit 50 watts and 418 watts extra at 100 watts output
SS30
Turned on no load: 9 watts total
With radio turned on low volume: 36 watts total
With radio transmitting: 215 watts total
With radio transmitting 100 watts: 306 watts total
In summary, power supply draws 27 watts extra to power radio and 206 watts extra to transmit 50 watts and 297 watts extra for 100 watts out
Overall efficiency we see that RS20 is 37% at standby and 55% @ 50 watts and 55% @100 watts key down
And for the SS30 it is 55% at standby and 80% @50 watts and 79% @100 watts at key down
It has gotten my attention and I am retiring RS20a to standby duty. A even bigger linear supply would likely have even greater efficiency losses at light to moderate loads. The RS20 uses more power from wall socket at 50 watts out than SS30 does at 100 watts out. Very good reason to go with a switching supply here.
