Author Topic: Field Day Question  (Read 1802 times)
N0UY
« on: June 08, 2007, 10:33:27 AM »
Normally we run 2 transmitters with two operators powered by batteries.  Our exchange normally is 2B MN.
This year other people want to help operate so it is my impression we should use 2A MN because of 2 transmitters and 4 or 5 operators.  Is this correct?
tnx   ray
N0UY
« Reply #1 on: June 08, 2007, 10:53:23 AM »
I forgot to mention we will still be running battery power and 100 watts.
cul  ray
N8UZE
« Reply #2 on: June 08, 2007, 12:03:29 PM »
Yes, it is based on the number of stations not operators.  See the ARRL website for complete rules.
AB3EI
« Reply #3 on: June 08, 2007, 05:21:44 PM »
Your operating class will be 2A, since you'll be more than two ops running 100w, regardless of your emergency power source.  Were you running less than 5w, you'd submit your log as 2A-Battery.  See:
http://www.arrl.org/contests/rules/2007/fd.html
specifically Section 4.
See you on the air!
AB3EI
PS - Listen for W3OK, 2A EPA! =)
N8UZE
« Reply #4 on: June 09, 2007, 05:15:37 AM »
Direct Quotes from the rules:
"4. Entry Categories: Field Day entries are classified according to the maximum number of simultaneously transmitted signals, followed by a designator indicating the nature of their individual or group participation."
"4.1. (Class A) Club / non-club portable: Club or a non-club group of three or more persons set up specifically for Field Day."
"4.3. (Class B) One or two person portable: A Field Day station set up and operated by no more than two persons"
2A is two transmitters and is 3 or more operators.
2B is two transmitters and less than 3 operators.
N0UY
« Reply #5 on: June 09, 2007, 05:16:50 AM »
OK, Thanks for the replies.  Wish all of you a safe and enjoyable FD 2007.  cu on the bands.   ray
