Author Topic: Manual tuning with IC-7000  (Read 2211 times)
AC0TU
« on: March 05, 2011, 07:14:47 PM »
I just ordered my new IC-7000 (not here yet).  I did not order an automatic tuner since I already have a manual tuner MFJ-941E to use at home.  I do not see anywhere in the manual a safe procedure for tuning manually with this radio.  I assume I can go to cw mode, back off power and tune like I did with my older transmitters.  Or can I use this "tune" button to help out even though an automatic tuner is not connected?  Thanks.
AD5X
« Reply #1 on: March 05, 2011, 08:57:59 PM »
I use a very simple tuning interface that puts the radio into a 10-watt tuning mode at the flip of a switch.  It is in the "Articles" section at www.ad5x.com.  Here's the direct link: www.ad5x.com/images/Articles/TuningIntfc706.pdf.
Phil - AD5X
VE3FMC
« Reply #2 on: March 14, 2011, 09:23:12 AM »
Put the rig in the AM mode and lower the power and tune your antenna that way. One thing you would find very helpful is to make a chart with your manual tuner settings on it. That way you can change bands, use the chart to get the tuner very close to the proper settings. Then a quick AM carrier allows you to fine tune the tuner.
