Author Topic: Kenwood TS-940 Amp Relay  (Read 1711 times)
KC7WGA
« on: March 08, 2011, 06:22:39 PM »
I just purchased a Kenwood TS-940 and I'm trying to key a Collins 30l-1 using an Ameritron ARB-704. The relay works just fine on my Kenwood TS-520. I've changed the jumper settings in the 704 to all possibilities with no luck.
With the DIN plugged in I can hear a relay click in when the 940 is transmitting. Without it plugged in there is no relay click.
I felt RL1 and RL2 while transmitting and don't feel any "click" on those when the transmitting.  I read on a posting that RL1 or RL2 has something to do with the remote switch.
Any help would be appreciated.
73, KC7WGA
KA5IPF
« Reply #1 on: March 09, 2011, 01:07:20 PM »
You don't need the ARB. Make up a din plug with Pin 2 to the center of the phono plug and ground to ground.
The shield must be on the din plug to activate the switch that turns on the relay.
Clif
