Author Topic: Icom 718 tuner function  (Read 2591 times)
M5AEO
« on: April 07, 2011, 01:31:18 PM »
Does anyone know if it is possible to 'fool' the 'Tuner' function on the IC-718 into working without having the auto-tuner connected?
In the manual it says that pressing the 'Tuner' button with the auto-tuner connected causes the rig to radiate 10w of CW for tuning purposes; it then reverts to the previously selected mode and power level.
It would be great to be able to do this with my manual tuner.
I thought that fiddling with the auto tuner connector on the back may produce a solution?
Any ideas?
Jonathan, M5AEO, London.
N9VO
« Reply #1 on: April 07, 2011, 01:41:05 PM »
Sure it works. Add on on the ten-a-tuner or like circuits to the rear plug and it will make your rig think any autotuner is connected and put out approx a 10 watt signal. Just like you want.
M5AEO
« Reply #2 on: April 07, 2011, 01:50:33 PM »
Thank you N9VO!  Can you point me to a wiring / circuit diagram??
M5AEO
N4IAG
« Reply #3 on: April 07, 2011, 03:13:34 PM »
Here's a site that sells them.
http://www.betterrf.com/706-tune.html
Also, there are plans on the Internet if you search.
I want to die peacefully in my sleep like my grandfather, not screaming in terror like his passengers.
VK2FXXX
« Reply #4 on: April 09, 2011, 04:37:10 AM »
for free!(almost)
http://www.hampedia.net/icom/ic-718.php
enjoy
 Brendan
« Last Edit: April 09, 2011, 04:39:23 AM by VK2FXXX » Logged
KB3MDT
« Reply #5 on: April 09, 2011, 07:15:27 PM »
Hi,
    I have been using the http://www.betterrf.com/706-tune.html
plug for a couple of years with great success.  Its nothing more than the right connector with a little circuit board on it.   I think it was fairly cheap - under $20.   I bought it the same time I bought the radio.
Ken
KB3MDT
KB3MDT
« Reply #6 on: April 09, 2011, 07:19:50 PM »
Hi,
   I forgot to say the Betterrf.com adapter works with the front tuner button on the ICOM 718.   No need for a separate switch.   You have to go into the ICOM setup Menu and tell it you have Tuner Type 4 to make it work.   The adapter came with a short instruction sheet  (About size of postcard) that walks you through it.
  One of the circuits on the internet requires you add your own switch.
Ken
KB3MDT
