Author Topic: Using a PC Mic with an Audio Mixer  (Read 2103 times)
K9BAY
« on: May 13, 2011, 06:56:19 PM »
I have a audio mixer.  Is the Mic input on a typical mixer compatible with a PC microphone? I can plug a MP3 player and it plays fine through the mic input on the mixer, but the PC microphone doesn't work at all.  The mixer has a Aux input that I will use for the MP3 playback (which according to the manual, that is what it is designed for.    I get grounding feedback through the PC laptop as I am testing and it gets worse when I move the level of the mic up using the PC Mic. There are also two Aux inputs via RCA jacks on the mixer (MP3 player as a source). I assume plugging a microphone to an y cable (1/8 mini to RCA) to the Aux isn't going to work either.
There are some specs included with the mixer.  Let me know what input sensitivity, input overload etc, would impact a PC Mic working via the Mic input on an Audiomixer.
What would make a PC Microphone not compatible with a mixer input (impedance mismatch, etc)?
Any ideas?
Thanks!
Barry
KF6QEX
« Reply #1 on: May 15, 2011, 12:19:51 AM »
"PC microphones" using a mini-stereo jack, need 5V power (supplied by the soundcard mic jack -hence the term "PC Microphone"
K9BAY
« Reply #2 on: May 15, 2011, 08:21:45 AM »
Thanks for the info.  Someone recommended this article, so I thought I would pass it along.  It should be a pretty simple circuit to build.
http://www.epanorama.net/circuits/microphone_powering.html
Thanks!
