Author Topic: Ameritron QSK  (Read 4030 times)
K5NT
« on: August 25, 2001, 11:01:14 AM »
Has anyone had any experience with the Ameritron QSK accessory?  Since it used PIN diodes, it should be fast and silent.  I would like to hear from someone who has used it before making my choice of amps.
73, and thanks.
K5NT
« Reply #1 on: August 29, 2001, 06:18:26 PM »
Yep, I have (QSK-5).  Sorry about the delayed reply, I just noticed your question.
It works, never had any problems with it.  One small quirk, if you call it that: You can't use an "internal keyer" and the QSK-5 together.  You must use a keyer that actually plugs into the QSK-5, and then the QSK-5 is used to key the amplifier, key the exciter, and switch the RF in the correct sequence to prevent blowing up most of your station!
73 de Steve WB2WIK/6
N7YW
« Reply #2 on: March 01, 2002, 08:54:54 PM »
Yes, it is fast and silent ... BUT ... your first character closes the amp's T/R relay, which stays closed until you pause 3 seconds, at which time the relay opens. So you still have the "clunk" from the amp's relay. Watch that when evaluating which one to buy.
73 Gene N7YW
