Author Topic: CS-V8000 under Windows 7  (Read 1157 times)
PU2PLL
« on: July 08, 2011, 03:41:47 PM »
Hi, I need to run a copy of the ICOM's memory management software of the IC-V8000 VHF radio under Windows 7. I know that this release of the software is compatible with windows XP but what about Windows 7? I have tried change properties as compatible with Windows XP but either way it doesn't run I got the message:
Check the following:
The RS232C port settings;
Cloning cable connections;
Appropriate cloning software for the transceiver is being used;
KI4GTD
« Reply #1 on: July 22, 2011, 04:22:32 PM »
Sort of a general problem with programs not specifically designed for Windows 7 is that you might need to right-click on it instead of left-click on the start menu, then click "Run as Administrator." This should give you full rights to the serial ports, etc., if that's the only problem.
73 Brian KI4GTD
