Author Topic: DSP and "special" speakers  (Read 756 times)
VE4BLB
« on: July 22, 2011, 10:43:54 AM »
Hi all, I have a Kenwood TS560 with DSP and other audio filters. I have a LOT of, I believe, white noise in my area. I'm not referring to power line or whistles, just S9 on all bands. I have a Cushcraft R8 vertical.
I wonder if buying one of those "special" speakers is worth the cost? Just using it in the shack, no mobile.
73 de me BLB
« Reply #1 on: July 22, 2011, 10:54:32 AM »
Odds are if it's on all bands and that strong, "your area" is your house.
I doubt much if any audio processing is going to help you here.  I would start with isolating the source of the noise.  First step is to kill the breakers and make sure it's not coming from within your home.
VA7CPC
« Reply #2 on: July 22, 2011, 11:57:03 AM »
What K5LXP says . . .
"DSP" is not the same as "magical noise reduction".  If a CW or SSB signal is inaudible without DSP, it will be inaudible _with_ DSP.
        Charles
VE4BLB
« Reply #3 on: July 22, 2011, 01:06:49 PM »
Mark, the noise is broadband and covers about two square miles separated by a large river. There is something in the terrain or something. Maybe if I switch to a beam?Huh
WA3SKN
« Reply #4 on: July 22, 2011, 01:34:25 PM »
Special speakers will not help... you need to find the noise source(s).
First verify you lose the noise when you disconnect the antenna.  That will prove it is incoming via the antenna and you can work from there.
Do you have an AM radio with a ferrite bar antenna?  It can be useful looking for this type thing.
-Mike.
N4NYY
« Reply #5 on: July 22, 2011, 04:47:18 PM »
I use a $20 Uniden extension speaker. I have heard that some of the more expensive speakers do sound much better.
« Reply #6 on: July 22, 2011, 05:02:19 PM »
I have to disagree. There has been a few times when copy got tuff or unreadable and I switched rigs and pulled it out with DSP. Lot of variables here.
KS2G
« Reply #7 on: July 23, 2011, 07:18:10 PM »
Have to agree with W8JX.
It may not be "magical noise reduction" but current technology IF DSP can produce striking improvements in readability.
The DSP noise reduction in my recently-acquired Kenwood TS-590S can definitely dig barely audible signals out of the noise.
Mel - KS2G
