Author Topic: mastering the tunning of cw signals  (Read 2096 times)
M3CMA
« on: December 23, 2002, 09:01:14 PM »
Hi.
I am trying very hard to put my long hours of practice off the air into practice on the air!
Problem I have is that I do not appear to have mastered the art of setting the tx/rx for cw.
I have a perfect tunned morse signal yet when I attempt to reply to the CQ I have never managed to get a single response.
What is the trick here, should I have some form of offset configured?
Thanks
Simon.
K5CEY
« Reply #1 on: December 25, 2002, 09:43:49 PM »
Simon, normally you would not use any kind of offset for a CW contact. Have you ever been able to make a contact with anyone with your present set up? This is where it's nice to have a local ham to check your transmitted signal.
               John  K5CEY
M3CMA
« Reply #2 on: December 28, 2002, 07:30:11 AM »
Thanks for the reply.  My mistake.  I was putting no CW signal out at all!!  The trick is to read the instructions for the set..
dit's and dah's are certainly now flowing freely.
Thanks
Simon
N6KB
« Reply #3 on: January 17, 2003, 04:14:19 PM »
Simon, I am glad to hear that you found the problem and are now on the air making CW QSOs. Getting your transmitter on the right frequency is a common problem for CW operators for a couple of reasons. One reason is we may not know what frequency the other station is listening to. Even if we do know where we want our transmit signal to be, it may not be so easy to get it exactly there. Ideally the sidetone that the transceiver produces when we key it would be an exact representation of where in our receiver passband the transmit signal will be. This is not always the case either because of a design that did not consider this, misalignment, or other settings on the radio that change it such as RIT or operating split. There are a lot of things that can go wrong. If you learn how the radio works and how to get your CW TX signal right where you want it, your success at CW operating will be much greater.
