Author Topic: Echo link and Kaspersky settings  (Read 2088 times)
ZL1MHS
« on: August 31, 2011, 10:34:01 PM »
Hoping somebody can help me get echo link running, I have a Huawei SmartAX MT882 router and Kaspersky internet security 2011.
I have tried and tried to configure both to run echo link but with no success and keep getting UDP receive failed on the firewall/router test, its showing the TCP connectivity as succeeding.
I think its a setting I might be missing in Kaspersky so if there is somebody could help or advise me that would be great.
Many thanks
Kevin
ZL1MHS
KD8DEY
« Reply #1 on: September 01, 2011, 09:41:55 AM »
Never mentioned what version of windows you are running.
On Windows XP I went into the firewall and set it up by not just relying on the program itself in the list by adding each port to the exception list
Echolink1 5198 udp
echolink2 5199 udp
echolink3 5200 tcp
Then made sure each port was open in my router.....
then made exceptions in my software firewall
I'm not familiar with kaspersky but if it has a software firewall there should be some way to add the exception.
ZL1MHS
« Reply #2 on: September 01, 2011, 03:55:16 PM »
Hi
Thanks for the reply, am running XP pro, I have added the ports to the XP firewall but still doesn't work, Sad
KD8DEY
« Reply #3 on: September 01, 2011, 04:14:12 PM »
you will also need to add the ports to your router and if kaspersky has a firewall into it too
Here is an example for a program called Emule
http://portforward.com/english/routers/port_forwarding/Huawei/SmartAX-MT882/eMule.htm
same principal applies
« Last Edit: September 01, 2011, 04:17:07 PM by KD8DEY » Logged
ZL1MHS
« Reply #4 on: September 02, 2011, 01:25:12 PM »
Done all that and made exceptions in Kaspersky but still failing on UDP
KD8DEY
« Reply #5 on: September 04, 2011, 10:34:58 AM »
Did you try rebooting the router and computer to make sure that the new settings take effect?
try temporarily disabling kasperskey to eliminate one of the variables.
