Author Topic: HRD Multiple Radios  (Read 2528 times)
W1KRK
« on: September 05, 2011, 12:32:59 PM »
I have HRD running fine with my IC-7600 and want to link up my TS-590 also. Is this possible? as I can't seem to find a menu for adding a rig. HRD V5 the latest version.
Thanx
N4KD
« Reply #1 on: September 06, 2011, 05:37:00 AM »
I suspect this is very much the same for HRD5 and HRD4. When the application starts, you should see a window that offers you a choice of rigs to connect with. That same window allows you to configure a new connection. Add the new rig and you're there.
Is that what you're looking for?
- Dave, N4KD
KB1NXE
« Reply #2 on: September 06, 2011, 01:40:33 PM »
Are you talking simultaneously?
N4KD
« Reply #3 on: September 06, 2011, 01:54:41 PM »
Simultaneously works too. I think there's a menu item called "Connect" and if you select it, you get the opening connection window. With a different serial port, you get the connection on the second radio in a second window. I run my TS-2000 and K-3 simultaneously.
I'll check the connect/configure process when I get back to the shack.
- Dave, N4KD
W7QPZ
« Reply #4 on: September 09, 2011, 07:58:02 PM »
It is simple run multiple instances of HRD and switch between them
Lou
W5DQ
« Reply #5 on: September 22, 2011, 08:50:38 AM »
Lou
Surely you jest?Huh? Multiple instances of a program to interface to multiple ports? Are we talking DOS here?! Even DX Lab Suite will interface up to 4 rigs at once in ONE instance of COMMANDER interface.
Gene W5DQ
Ridgecrest, CA - DM15dp
www.radioroom.org
AA4HA
« Reply #6 on: September 25, 2011, 09:41:16 AM »
Lou
Sometimes apps are quirky about where they store temporary files and multiple instances can cross-corrupt each other. It would be nice if you could either run it as a fully integrated platform with multiple radios working in concert but it may require a significant change in the app to make that happen. When it does work out that way with any app I have it is a pleasant surprise.
Ms. Tisha Hayes, AA4HA
Lookout Mountain, Alabama
