Author Topic: Keyers  (Read 1866 times)
KB9SDS
« on: April 19, 2003, 03:52:49 PM »
I have a Kenwood TR-9130 all-mode 2m radio. I would like to try working CW on it, but I don't know if it needs a keyer and if it does what would be the best one for the job. I also have a Yaesu FT-101 EX (waiting in the wings for my upgrade). Do I need a keyer for that as well or can I connect the key directly into the radio.
N8UZE
« Reply #1 on: April 20, 2003, 08:24:28 AM »
You should be able to connect a straight key directly to the radios.  However if you want to use paddles or a bug, you will need a keyer.  I.e.  connect the paddles or bug to the keyer and the keyer to the radio.
« Reply #2 on: April 21, 2003, 01:07:03 PM »
A "bug" doesn't require any sort of keyer.  It is an electromechanical key that forms dits and dahs as you use it, with all work done mechanically; there's no powered electronics involved.
Using electronic keying is a different story, and an outboard electronic keyer is required with both rigs mentioned.
But, a simple hand key, or a "bug," can be plugged straight into the KEY jack of either radio and used on CW without any other accessories.
WB2WIK/6
KC0JBJ
« Reply #3 on: May 25, 2003, 02:28:26 AM »
"A "bug" doesn't require any sort of keyer. It is an electromechanical key that forms dits and dahs as you use it, with all work done mechanically; there's no powered electronics involved."
Hmm, bascially correct, except the term "bug" is used to describe a SEMI-automatic key.  The dits are formed mechanically as you state, but the dahs are formed manually by the operator.
I have heard of individuals homebrewing a true fully-automatic electro-mechanical key that does both dits and dahs, but the classic "bug", e.g. Vibroplex et al, is semi-automatic.
