Author Topic: Antenna Analyzer help - RigExpert AA-230 Pro or AA-520 ?  (Read 4813 times)
W7KB
« Reply #15 on: September 11, 2011, 09:31:38 AM »
Buy the AA-520.If you cannot afford it,buy the AA-230.Why buy the MFJ when the Rig Expert is within your budget?
STAYVERTICAL
« Reply #16 on: September 16, 2011, 12:17:20 AM »
I agree - as the owner of two analysers an MFJ269 and a VK5JST kit built , I have found they are both rugged and
efficient as far as my experience goes.
But - times move on, and the neat display and extra features of the RigExpert units would make them nice to use.
As others have said, you can figure out almost any attribute of an antenna or feedline from just the resistance and
reactance of the antenna reading, but if the device does the calculations, why not go with it.
Even though I don't often use 70cm - I would go with this functionality, you may need it and then you will be glad
you have it. $100 is not much more for the increased functionality. As regards different feedline impedances - not
very important as its pretty easy to calculate this with simple math, 50 ohms will be your most used anyway.
Good luck and have fun - an antenna analyser is really a Digital voltmeter for RF and you will not regret getting one.
73s
« Last Edit: September 16, 2011, 12:23:39 AM by STAYVERTICAL » Logged
K7CF
« Reply #17 on: April 14, 2012, 08:11:11 PM »
I looked at what I would use more.
I have an MFJ 269, CIA-HF, and Analyst HF. along with AIM 1470C
I now have a Rigexpert 54. It goes up to 50 MHZ
I think. Above 50 mhz I can use the MFJ 269.
I have the sweep capability.
But I think I like the Rig Expert 54 and I will probably
use it before the others just because of the ease of use.
I don't goof around with 2 meters and above enough to
use the analyzer for those frequencies. SWR is a good enough
indication of whether it is OK.
But, with HF antennas, I try different ones looking for the
"Holy Grail" of antennas and there is more that can go
wrong. The Rig Expert 54 gives a lot of bang for the $350 bucks.
Watching the sweep and having the multi-band sweeps of an antenna
is a plus. And it uses AA batteries.
