Author Topic: RF Choke  (Read 717 times)
N4MJG
« on: September 08, 2011, 09:02:16 PM »
I have a question i have carolina windom about 40 ft with 1.1 baun ,i just brought coax from huntsville ala. hamfest last month ! the question is does it matter where you put RF choke top or bottom.
I don't know if is dumb question or good question ? i did do 6' choke about 10 turns if remember right !
I had to replace the old coax since someone forgot to seal the coax since i was sick that day  Cry
Jackie
N4MJG
W5CPT
« Reply #1 on: September 08, 2011, 10:09:05 PM »
A choke at the feed point isolates the feed line from the antenna - Is this one of those "both horizontal & vertical" antennas? If so the choke should be at the bottom of the vertical section - if not it should be at the feed.
Clint - W5CPT -
N4MJG
« Reply #2 on: September 09, 2011, 06:40:23 AM »
ok thanks i had my on bottom in the past !
Jackie
N4MJG
