Author Topic: Echolink router problem.  (Read 2503 times)
N4NDX
« on: September 11, 2011, 06:28:00 PM »
I`m new with Echolink and I`m ready to play but I can`t get connected and was wondering if anyone knows a way around home routers.
KB2YAN
« Reply #1 on: September 12, 2011, 01:02:54 AM »
You need to open ports 5198 to 5200 on any hardware and/or software firewalls, and forward those ports to the local IP assigned to your computer.
N4NDX
« Reply #2 on: September 12, 2011, 06:33:30 AM »
I tried to follow your directions but had no luck finding the ports nor where to go to find them, I went to fire wall and browse the page and did not take me where I needed to be. I saw were you allow or not a program but that was as far as I went. Any other suggestions.
KD8DEY
« Reply #3 on: September 12, 2011, 08:36:15 AM »
It would help if you mentioned the type of router you have along with your windows version.
usually to access router settings you type in the routers IP address in your browser then type in the default name and password to get into the settings menu (If you haven't already changed the defaults for security reasons).
Then you will need to open ports 5198-5200 and set up port forwarding to the IP address assigned by the router for the computer that you are running echo link on.
N4NDX
« Reply #4 on: September 12, 2011, 08:46:18 AM »
I`m using a Belkin router and Windows 7 on my PC.
David
KD8DEY
« Reply #5 on: September 12, 2011, 10:24:48 AM »
David
Router Model number?
K5WLR
« Reply #6 on: September 12, 2011, 10:43:37 AM »
Maybe this might help. Had issues with Echolink running through my router. I was setting ports 5198 and 5199 for UDP only. It did not work. Just for snicks and grins I opened both ports for both TCP and UDP. Success! It now works! Give that a try and see if it solves your Echolink problem.
73!  Cheesy
Will Rogers
W4WLR
N4NDX
« Reply #7 on: September 12, 2011, 10:49:18 AM »
David
Model # F5D8233-4v3
Ver 3100
KD8DEY
« Reply #8 on: September 12, 2011, 11:31:54 AM »
http://portforward.com/english/routers/port_forwarding/Belkin/F5D8233-4v3/Echolink.htm
http://www.sevenforums.com/tutorials/542-windows-firewall-add-remove-exception.html
« Last Edit: September 12, 2011, 12:00:50 PM by KD8DEY » Logged
KD8DEY
« Reply #9 on: September 13, 2011, 05:17:53 PM »
No update??....
N4NDX
« Reply #10 on: September 13, 2011, 08:24:03 PM »
I had to leave out of town for business and not back yet, but I will keep you guys inform when I get back. Thanks for keeping up.
73 de David/n4ndx
