Author Topic: TS-520S semi-automatic break-in CW  (Read 1757 times)
N6LI
« on: June 20, 2003, 01:20:55 PM »
It appears that the TS-520S has semi-automatic break-in capability in the CW mode, but I do not know how to get it to work. I always have to flip the Send/Recv switch back and forth to transmit then receive.
I have the VOX switch on and have cranked up the sidetone volume and played with the VOX controls on the side of the rig but have had no luck.
Any CW ops using a TS-520S that have any suggestions?
Please reply here or better yet email me at n6li@arrl.net if you can be of assistance.
TIA.
Jim N6LI
N8UZE
« Reply #1 on: June 20, 2003, 06:42:49 PM »
As far as I know, all Kenwood radios work the same way in this regard.  All you should need to do is have the mode set as CW and the VOX turned on.  It should then transmit whenever you key.  If it doesn't, there is probably something wrong with the radio.
« Reply #2 on: June 24, 2003, 06:15:31 PM »
That's correct, there's something wrong with the rig.  The TS-520S is in the "semi break in" mode as soon as you flip the VOX switch ON, when the rig's in the CW mode to begin with.  Only the VOX DELAY (the timing of the relay drop-out) is actually adjustable in CW; the other controls (SENSITIVITY and ANTI-VOX) work only in the SSB mode.
Question: If you swith to SSB and use a microphone, does the VOX work??  If not, your VOX circuit doesn't work.  If so, then your VOX circuit is working, but for some reason doesn't see the signal from the key closure.  Should be easy to isolate and fix.
WB2WIK/6
N6LI
« Reply #3 on: July 03, 2003, 06:44:09 PM »
Thanks. I have verified the VOX is working by jumpering the speaker mike for my HT to the mike input of the 520s. So that narrows things down quite a bit.
