Author Topic: Wouxun KG-UV3D Programming cross band operation  (Read 3960 times)
K2PHD
« on: September 29, 2011, 10:39:21 AM »
Can the Wouxun KG-UV3D be programmed so that you can set up a memory channel to transmit on 2 meters and reveive of 440?
KU8K
« Reply #1 on: October 04, 2011, 06:11:14 AM »
I don't have a Wouxun but an operator I know has one and the answer is yes.  How is not an answer I can give you, but at least you know that the answer is out there. I hope this helps.
