Author Topic: Vibroplex Champion Contact Installation  (Read 678 times)
AA4PK
« on: May 31, 2003, 01:45:20 AM »
I recently unearthed my old Vibroplex Champion keyer.  Unfortunately, the dot contact point is missing from the contact screw.  I purchased a new contact point from Vibroplex.  How does the contact point get attached to the contact screw?  It doesn't seem to fit in when I try to press the contact point into the opening on the screw.
N0IBY
« Reply #1 on: June 10, 2003, 11:05:53 PM »
You probably ordered your new contact from Vibroplex.com, so i'm sure you've looked around there. About the only thing they have is an exploded drawing of your bug here: http://www.vibroplex.com/New_Folder/CBUGDRAW.htm . Don't know if that helps any.
W9GB
« Reply #2 on: November 03, 2003, 09:28:35 PM »
I use a panavise with plastic or wood jaws (not metal -- whcih will destroy the contact).  Slowly press fit ... it will work !
w9gb
