Author Topic: Beacon for 10 or 20 meters  (Read 2140 times)
W4HEW
« on: November 22, 2003, 01:04:12 PM »
Does anyone out there know where I can buy a 10 or 20 meter beacon, already built? Thanks  Harold  W4HEW
hewillis@alltel.net
N9AVY
« Reply #1 on: January 01, 2004, 02:20:03 PM »
My 10m beacon uses a Freakin' Beacon Ider which was purchased at Dayton 2003. Built it at motel overnight and installed it on HTX-100 when I got home. Beacon IDer is running smoothly ever since.
This just keys the xmtr. You'll have to supply the xmtr and antenna. If you use a Radio Shack HTX-100 be sure to put it several miles from your QTH or else plan on not using 10 meters; the rig puts out all sorts of interesting "noises" across the band.
For more info on beacons check out hfbeacons@explore.plus.com
Good luck !
Jerry  N9AVY
N8CPA
« Reply #2 on: December 31, 2003, 12:51:20 PM »
I just heard about one recently called the freakin' beacon.  Unfortunately, I don't have the url.  But, if you Google the name "freakin' beacon" I'm sure you'll find a link.
Steve
