Author Topic: Slow code net ?  (Read 1621 times)
KC2LCZ
« on: January 10, 2004, 10:07:23 AM »
I'm a general, fairly new to the hobby and would like to try code. Does anyone know of a slow code net where I could get my feet wet?  Thanks..Tom
KG9HV
« Reply #1 on: January 10, 2004, 11:18:42 AM »
http://www.qsl.net/ki8du/netsked3.htm
Go to the above listed website and the slow nets are
listed in blue. There is plenty of these type nets.
Good luck
73 KG9HV
W4KRH
« Reply #2 on: January 11, 2004, 12:04:11 AM »
Also - checkout: http://www.hamhq.org/
This is run by a real good bunch of folks that enjoy CW. You can find folks out there that would be glad to qso with you and qrs with you as you build your speed.
KC2LCZ
« Reply #3 on: January 11, 2004, 09:08:10 AM »
Thanks, Now I just need to get up the nerve for that first time........Tom
NJ0E
« Reply #4 on: January 11, 2004, 02:45:43 PM »
i participate in the texas slow net. it is a cw
traffic handling training net, so you can kill two
birds with one stone; increase your cw proficiency
*and* learn cw traffic handling at the same time.
now, how's that for a deal?
it meets each evening at 8 pm central
standard or daylight savings time. the
frequency is 3719 khz.
don't worry if you're not from texas; the most
frequent net control is in oklahoma city, and we've
recently had a fella frequently checking in from
montana.
scott nj0e
N2XE
« Reply #5 on: January 13, 2004, 03:41:23 PM »
Hi Tom,
Just call CQ at the speed you feel comfortable with and someone will answer (usually at your speed).  If not just tell them to QRS (send slower).
Don't be shy, plenty of us out there have just as much fun at 5 WPM as 50 WPM.
See you an the air!
N2XE
KD2DBM
« Reply #6 on: January 15, 2004, 03:43:39 PM »
Tom;
You can check in on Thursdays at 8:00PM EST on 3705 to the CW net there. I check in as much as I can and It is a GREAT!!! Bunch of guys, They slow right down so you can ACTUALLY understand what they're saying ....hi..hi....
Bill
KC2LCZ
« Reply #7 on: January 18, 2004, 01:24:11 AM »
Thanks again for all your suggestions, I'll be giving it a try real soon!
73 _.. .  KC2LCZ
N9BOR
« Reply #8 on: January 20, 2004, 09:18:30 AM »
K9YA Code Nets
Fast Net
Every first Wednesday of the month, 7.137 MHz (plus or minus QRM) at 7:00 P.M. (0100 Z, Thursday). Check in, exchange FISTS numbers or hang around for a chat. The Fast Net is called at 20+ wpm.
Slow Net
Every 2nd, 3rd and 4th Wednesday of the month, 7.137 MHz (plus or minus QRM) at 7:00 P.M. (0100 Z, Thursday). Check in, exchange FISTS numbers or hang around for a chat. The Slow Net is called at 10-wpm, but speed will be adjusted to that of the slowest operator.
http://www.qsl.net/k9ya
