Author Topic: HiMound/Skillman BK-100 bearings?  (Read 1337 times)
KE4MOB
« on: October 15, 2003, 12:43:18 PM »
I won this BK-100 on eBay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3049037452
It seems to work well and feel good (smooth and no slop), but I'm kinda concerned...in doing a teardown and cleaning last night (looked like a smoker once owned it) I discovered there are no bearings (ball, needle, etc.) in the lower pivot cup.  Should there be and if so, what type and size?? If someone has a pic of what it should look like, I'd be very appreciative.
On mine, all that I have are two jeweled pivots on the lever arm that fit into receiving cups--much like the  bearing system on an old J-38 straight key.
W9GB
« Reply #1 on: October 30, 2003, 03:59:54 PM »
Parts (weights, replacement clear cover) for the HiMound BK-100 can be obtained from MorseX. IF you have a specific quesiton - Marshall should be able to answer!
http://www.morsex.com/himound/
73 de Greg
w9gb
KE4MOB
« Reply #2 on: January 21, 2004, 11:38:58 AM »
Update:
There are at least two versions of this bug: one with and one without ball bearings.  I have owned examples of each.  The non-ball bearing models seem to have a little higher quality.
Check out http:\\www.qsl.net\ke4mob\bk100.html
I think the balls are of either 1 or 1.5 mm in diameter, so if you lose them, you might be able to get replacements from McMaster-Carr or a hobby supply.
Steve, KE4MOB
