Author Topic: Bencher ST-1 Single paddle keyer  (Read 4713 times)
WK0F
« on: November 22, 2003, 11:44:11 PM »
Has anyone used one of these non-iambic single paddle keyers?  How do they compare to the Vibroplex Vibrokeyer?  I have used the ST-2 iambic keyer and just can't get used to using iambic keyers.
Thanks and 73,
Terry, WK0F
« Reply #1 on: November 24, 2003, 03:23:31 PM »
Most keyers can operate iambic or non-iambic without changing from dual lever to single lever key paddles.  Even the built-in keyers in most all modern transceivers (all that I've seen or used) have this function as a switchable one, usually via a start-up menu.
Instead of buying a new paddle, did you investigate simply shutting OFF the iambic mode in your keyer?
WB2WIK/6
VA7CPC
« Reply #2 on: December 02, 2003, 09:25:39 PM »
Now you have me confused.
On my IC-706, there's a choice between "normal", "reverse", and "bug" keyer action.  I understand how those work.
What does "non-iambic" keying mean,  when you have a double paddle connected?
Just intrigued . . .
KE4DRN
« Reply #3 on: December 03, 2003, 12:08:36 AM »
Hi,
Check this out, hope this helps !
http://www.eham.net/forums/CW/1193
73 james
N8CPA
« Reply #4 on: December 31, 2003, 12:43:02 PM »
Iambic means that both dots and dashes will be self-completing, and of uniform length. Hold the dit lever, a string of dits will be sent; hold the dah lever, a string of dahs will be sent.
Non-iambic emulates a bug:  Hold the dit lever, a string of dits will be sent.  Hold the dah, a single long dash will be sent until let go.  Non-iambic can be a real challenge to get right, especially if you're used to iambic.
Steve
W4SK
« Reply #5 on: January 30, 2004, 09:03:33 PM »
I have two of the Bencher ST-1 paddles.  They are very similar to the K8FYO (SK) made paddles.  I also have a Vibroplex single-lever paddle, which I like, but the Bencher is more amenable to precision adjustment.  If you dont go 'iambic', you wont be disappointed with the Bencher ST-1.
