Author Topic: SuperSimpleSoundDoppler  (Read 1192 times)
PA3BNX
« on: October 20, 2011, 04:23:19 AM »
Hello All,
I have written software for a VHF DSP Doppler Direction Finder
The project is called a SuperSimpleSoundDoppler.
You can build it for about 20$
You need:
A PC with a stereo input Soundcard
A VHF FM porto, scanner or mobile set
A GPS Mouse with NMEA0183 output
The homebuild SuperSimpleDopplerPeiler
The SuperSimpleSoundDoppler consists off:
4x vertical whips(abt 50 cm ) mounted on a round board
of about 60 cm diameter with a switcher unit.
A electronics board with 3 transistors
and 2 cheap ic's 4013 and 4001 and
a 5 volt voltage regulator.
The software shows a pelorus and has it's
own MyMapping software witch works with UI-View32 Maps
But it also can plot on Google-Earth through a kml file.
You can also use Mymapping with a doppler
that gives a mixed GPS and Agrelo format.
Existing Dopplerfinders can be very easy interfaced by just a lowpass filter
of some R, c's and a transistor connected to one of the antenna switch signals.
You can find the free software on our Radio Club site.
http://www.pi4wag.nl/index.php/pseudo-doppler-radio-direction-finder
The software is updated regualairy.
In the software are all the circuit diagrams.
Suk6,
73's
PA3BNX
Lodewijk
QTH Rhenen
Country Netherlands
N0NB
« Reply #1 on: October 20, 2011, 04:35:17 AM »
Looks interesting.  Too bad it's relegated to Windows only.  Sad
73, de Nate
Marysville, KS
SKCC 6225
PA3BNX
« Reply #2 on: October 20, 2011, 10:14:00 AM »
Hello All,
Yes I know it is for Windows only but
I intend to write it also for the
IPad and Android if i have time to to that.
and have the equipment for it.
Anyone who wants to have it running on Linux
is free to write it in C or Perl  I think.
With the same hardware it should be possible to write
it for a program under Linux.
Maybe it's also possible to write it in mono.dot.net
I am very busy to rewrite SoundDoppler in Visual Basic 8.0
Just like MyMapping already is.
I am not a pro software writer I just do this for hobby.
73's
PA3BNX
Lodewijk
