Pages: [1] 2 3 Next   Go Down
Author Topic: Brainteaser  (Read 4358 times)
W5DXP
« on: November 02, 2011, 06:34:06 AM »
Here's a graphic of a black box containing one real-world component along with lab measurements made on the current in and current out of the black box. What's in the black box?
http://www.w5dxp.com/branteas.GIF
73, Cecil, www.w5dxp.com
« Reply #1 on: November 02, 2011, 08:52:13 AM »
If the black box is a passive part, my best guess is a 4:1 Balun.......
That would explain the output current being greater than the input current in the first two cases if the black box performs an impedance transformation.
Hey, someone had to go first...........................  Tongue
W5DXP
« Reply #2 on: November 02, 2011, 11:09:35 AM »
Yes, it is a passive part and no, it is not a 4:1 Balun nor any N:1 turns ratio transformer.
AC7ZN
« Reply #3 on: November 02, 2011, 01:08:49 PM »
Hi Cecil,
Can we assume, since transformers are eliminated, that it is also not a saturating tapped inductor (which could be considered a  form of autotransformer)?
Glenn AC7ZN
W5DXP
« Reply #4 on: November 02, 2011, 02:52:14 PM »
There's no known non-linearity like saturation. It is an extremely common linear component and this brainteaser has absolutely no tricks involved.
K7STO
« Reply #5 on: November 02, 2011, 08:36:28 PM »
I believe it is a capacitor. The answer I would like to know is how to change my Callsign after logging into the site to my new callsign.
W5DXP
« Reply #6 on: November 03, 2011, 04:47:44 AM »
How would a capacitor manage to effect a 60% increase in output current over input current?
« Reply #7 on: November 03, 2011, 07:07:55 AM »
Are the phases all positive as suggested, i.e. input leads the output?
G8HQP
« Reply #8 on: November 03, 2011, 07:59:46 AM »
Transmission line, impedance 1930 ohms, electrical length about 8.5m ?
W5DXP
« Reply #9 on: November 03, 2011, 10:26:49 AM »
Congratulations!!! Very close, but no cigar. The characteristic impedance is indeed 1930 ohms and the electrical length, assuming VF=1.0,  is indeed about 8.5m at 4 MHz, i.e. 41 electrical degrees.
But the device inside the black box was a 75m Texas Bugcatcher mobile loading coil.
WS3N
« Reply #10 on: November 03, 2011, 10:30:35 AM »
http://www.eham.net/about/loginhelp#new_callsign
« Reply #11 on: November 03, 2011, 12:46:21 PM »
...which makes it ready for burial. Excellent!
G8HQP
« Reply #12 on: November 03, 2011, 02:20:24 PM »
I was wondering where you could buy 1930 ohm coax cable! A big coil will of course have a high inductance and a relatively low capacitance (when compared to coax) so at some frequencies can behave like a section of transmission line.
My initial guess, before I carefully read the question, was a pi network as that has impedance inverting properties but then I saw that only one component was present. A pi network is of course a lumped approximation to a transmission line.
K0BG
« Reply #13 on: November 03, 2011, 03:49:07 PM »
Someone's mathematics is a bit off.
K7STO
« Reply #14 on: November 03, 2011, 04:41:26 PM »
Thanks Jack I appreciated the assistance.
Mike
Pages: [1] 2 3 Next   Go Up
