Author Topic: Equipment Shippen boxs  (Read 1001 times)
WA2AAR
« on: November 12, 2011, 06:32:24 PM »
Hi all
There was a company that I found on EHAM that makes box's for shippen equipment. I dint remember the name and I thought i book mark it. Does anyone know the name of the company?
Thanks
Bob - WA2AAR
WA2AAR
« Reply #1 on: November 12, 2011, 08:17:45 PM »
I found the company. if anybody is interested here is the URL
http://www.hamradioboxes.com
Thanks
Bob
WT8E
« Reply #2 on: February 15, 2012, 12:28:00 PM »
I heard some guys talking about shipping and one said this is the way he did it. After obtaining the proper size box he would wrap the radio in heavy plastic.  When that was done he took it to a professional packing company and they sprayed in top and bottom layers of expandable foam. He said when it dried all you had to do was just lift out either layer. He said the foam conformed to the radio and filled the cavities in a form fitting manner. I don't know if that would work or not, would there be a heat issue with the expandable foam,. Also wonder about the expandable foam cans you can buy a local stores.  What do you think?
W5FYI
« Reply #3 on: February 15, 2012, 02:10:58 PM »
Two concerns; heat and fumes. Some expanding-foam systems create enough heat to melt or distort plastic, and I would be leery of fumes that could contain corrosive materials.
Otherwise, I've seen the foam system work like a charm on various packaging problems. GL
K8GU
« Reply #4 on: February 16, 2012, 06:17:16 AM »
I tried the DIY foam-in-place technique myself and had no real problems with it, but I would offer the following cautions:  1.  it takes a deceiving quantity of foam, 2. I don't know how much the mechanical properties of foam insulation differ from those of real foam-in-place material.
I wouldn't really consider doing it myself again, but I would consider paying someone to do it.
