Author Topic: Age distribution of CW ops and CW Sweepstakes  (Read 5153 times)
N3QE
« on: November 15, 2011, 12:39:03 PM »
Part of the ARRL Sweepstakes exchange is the last two digits, of the year first licensed.
Below is a count of checks (with 1900 or 2000 added) that I logged in the most recent CW sweeps. Note the most obvious peak in late 50's/early 60's, with a long tail and what looks like a secondary peak in the mid-late 70's. It's encouraging to see new ops participating.
1924:1
1927:1
1933:1
1939:1
1944:1
1947:3
1948:3
1949:3
1950:3
1951:3
1952:7
1953:7
1954:13
1955:31
1956:15
1957:22
1958:25
1959:28
1960:26
1961:25
1962:31
1963:19
1964:13
1965:14
1966:8
1967:15
1968:16
1969:17
1970:12
1971:18
1972:23
1973:12
1974:7
1975:14
1976:26
1977:24
1978:11
1979:8
1980:5
1981:2
1982:5
1983:5
1984:4
1985:4
1986:4
1987:4
1988:4
1989:4
1990:3
1991:4
1992:2
1993:2
1994:2
1995:5
1996:4
1997:1
1998:1
1999:1
2000:1
2002:1
2003:1
2004:1
2005:4
2006:2
2007:1
2008:2
2009:2
2011:1
N2EY
« Reply #1 on: November 15, 2011, 01:55:57 PM »
Fascinating!
Couple of caveats:
1) The check can be the date of the operator or the station license. Club stations often use the station license date, and so do multiops.
2) Interesting peaks and valleys.
3) In general, more-experienced hams will tend to make more QSOs, both from having better skills and from having better stations. So they will be more common in contest logs.
73 de Jim, N2EY
ck 67
K3STX
« Reply #2 on: November 15, 2011, 07:45:32 PM »
My log mirrors that, with a peak at 1958-60, 62-62, and then 76-78. It is surprising from my log, and yours, that there was a BIG drop in 1979-80, what happened then?!?!?
Also, remember the Check is not REQUIRED to be the actual year of first license, it just must be the same for all contact. (Nobody ever "checks" your Check!) I know many guys who use "73" and "55" as checks because they are easy to copy and unlikely to require a repeat!
paul
VK3GDM
« Reply #3 on: November 16, 2011, 09:09:57 PM »
..that there was a BIG drop in 1979-80, what happened then?!?!?
They've now got small children.  Grin
There's a new wave of us forty+'s coming through.
David, VK3GDM
N3QE
« Reply #4 on: November 17, 2011, 05:40:00 AM »
Yeah, I see the big spike on 55 in the distribution I posted, I hadn't noticed that before.
I think the concept that 55 is easy to copy is a misconception spread by contesters concerned with nothing but rate, rate, rate and not caring about accuracy. I remember the Spanish station EE5E in a DX contest just a few years ago, by far it was the most commonly busted call. To me it sounded like a bozo with a stuck or runaway keyer paddle.
It's probably easier to copy all dits at a reasonable WPM (like 25) than it is at the speed that running big gun stations send their call in the DX contests (45 to 50 WPM).
Tim.
K3STX
« Reply #5 on: November 17, 2011, 06:04:43 AM »
My check was 78. It is busted ALL THE TIME as 77 or 88 or 87.
One of the guys I worked  (I think from PR?) had a check of 11 and he was cruising along at 30+ wpm. I had to ask again, it seemed odd that a newly licensed Ham would be chugging along in a contest at 30+wpm.
Any you are right, it IS all about rate (obviously). That is why sending a SIMPLE check increases rate and why EE5E is a silly callsign.
paul
N2EY
« Reply #6 on: November 17, 2011, 06:25:34 AM »
The check can be the date of the station rather than the op. A newly-formed club station could have a check of 11, yet be run by OTs. (In a multiop situation, you have to pick one check for the entire contest; you can't change the number when you change ops).
Some of the truly ancient checks on the list are probably club stations.
In fact, since mandatory licensing in the USA started in 1912 and there were club stations active before WW1 that survive today, we may soon see "overlap" checks.
73 de Jim, N2EY
CK 67
PA0BLAH
« Reply #7 on: November 17, 2011, 06:29:24 AM »
So,
I don't know what sweepstakes are, sort of trick of local shopping centre  to get you more buying than you are able to afford, and hence putting next recession in starting position, because at the time you pay your debts you can't spent the money at consumer products, that you really don't need.
However, I like to keep my innocence, and don't want to know what exactly sweepstakes has to do with CW.
When I see 2011 1 it must be the year of licensing and not the year of birth of the holder. Amazing then somebody licensed in 1924,
As a matter of fact, is this list not accepted as proof of my statement that CW is going to die within 30 years?
If not, why not?
N2EY
« Reply #8 on: November 17, 2011, 06:53:35 AM »
Sweepstakes is a contest that happens in November. Focused on North America. I have done all but one since 1968. A lot of fun because the exchange is not trivial.
As previously stated, the check can be the license year of the operator or the station. There are club stations in the USA that date from before World War One.
No.
If not, why not?
Because it's not a representative sample.
73 de Jim, N2EY
W5ESE
« Reply #9 on: November 18, 2011, 10:37:15 AM »
Maybe he just likes the call, and it has nothing to do with contesting?  Huh
May come as a shocker to some of you guys, but there are some hams that don't live for
contesting.
I also like his Swedish cousin's call, 'SE5E'.  Grin
Scott
K3STX
« Reply #10 on: November 18, 2011, 11:52:37 AM »
contesting.
EE5E is the contest callsign for EA5RS.
paul
AE6ZW
« Reply #11 on: November 25, 2011, 06:40:11 PM »
often in slow speed CW QSO, they send their age and how long been HAM.  I says most of HAM I had QSO with are 70 to 80 years old, once a while 60's rarly 40, 50 s
N2EY
« Reply #12 on: November 26, 2011, 08:22:37 AM »
Well, I'm 57 and been a ham 44 years.
Why do some folks write "ham" in all-capitals ("HAM")? It's not an acronym.
73 de Jim, N2EY
W5ESE
« Reply #13 on: November 26, 2011, 08:30:12 AM »
I just put in a minor effort. Here is the distribution from my log:
[scottm@shingleHills 2011]$ ./analyzeSSLog < W5ESE.LOG
1920    1
1930
1940    4
1950   27
1960   35
1970   21
1980    6
1990    2
2000    3
2010
total:  99
Quite a bulge from the 1950's through the 1970's.
Scott W5ESE
