Pages: Prev 1 2 [3] 4 5 6 Next   Go Down
Author Topic: which receiver do you use ?  (Read 138665 times)
WI0H
« Reply #30 on: April 20, 2012, 10:29:45 AM »
My primary radio these days is a JRC NRD-525. I got it used from universal back in 1997 and I still love it. I've got a lot of other radios, but this one is still my rig of choice.
AUSSIE
« Reply #31 on: May 05, 2012, 03:26:09 PM »
These are my hf receivers:
Aor-3030
Aor-7030
Alinco DX-R8 (2)
Drake SW-2
Drake-R8B
Grundig Satellit-750
Icom-R71A
Icom-R75 (2)
Jrc Nrd-535
Jrc Nrd-545
Kenwood-R5000
Lowe HF-235
Palstar-R30A
Rfspace SDR-IQ (2)
Ten Tec-320D
Ten Tec-340
Ten Tec-350D
Regards Lino..
« Last Edit: May 05, 2012, 09:52:57 PM by AUSSIE » Logged
K0SBV
« Reply #32 on: May 11, 2012, 08:13:59 AM »
I have used probably 15-20 receivers over the years, and currently use a Drake SW8 and Icom R75, but for BCB DXing, by far the best receiver I have ever used is a Hammarlund HQ-180A--still sorry I sold it back in the 1980's.
RADI0HEAD
« Reply #33 on: May 11, 2012, 04:27:19 PM »
AOR 7030+
Icom R8500
Palstar R30A
Eton E1
Sony 2010
Sony 7600GR
Grundig G5
KE5JPP
« Reply #34 on: May 13, 2012, 01:43:54 PM »
In the order listed from most used to least used:
SRL QS1R SDR Receiver
Microtelecom Perseus SDR Receiver
ICOM R9000
I have others, but they just sit on the shelf unused.
Gene
K8HU
« Reply #35 on: May 20, 2012, 06:31:56 PM »
Microtelecom Perseus, Winradio G33DDX Excalibur Pro and EAC Build, R390A.
Chuck Rippel
WA4HHG
KB3ZBE
« Reply #36 on: May 23, 2012, 09:19:45 PM »
Primary reciever at my base is an ICOM IC-R8500.
Small portable for camping, etc. is a Sony  ICF-SW40
Mike
KD8AMR
« Reply #37 on: May 24, 2012, 09:54:18 AM »
Icom R-75 and a modified Radio Shack DX-394.
K7LZR
« Reply #38 on: June 06, 2012, 12:13:45 AM »
FlexRadio Flex 1500, Icom IC-7200, Yaesu FT-817ND, and a few older tube receivers. For SWL, I find that the Flex 1500 is simply incredible because you can see as well as hear the signals, and the filter adjustments are virtually unlimited. And you can see and adjust the filter effects in real time. I have had SSB stations as close together as 2khz with a desired signal between them and I can adjust the Flex to dig it out. For AM listening, I have found nothing better. With the filter widened to about 10khz on an uncrowded band, the Flex sounds as good or better than the old Hallicrafters SX-28A which I had for many years.
A close second is the IC-7200 which also has a superb receiver with awesome digital filtering.
And the little FT-817nd is a decent performer for SWL use too, especially if you couple it to a good outboard AF DSP filter such as the Timewave DSP-9.
- Darrell/KA7BTV
GABRESEVEN
« Reply #39 on: June 06, 2012, 07:43:48 AM »
My primary HF receiver right now is an ICOM 737 - the transmit doesn't work because it was disabled by the previous owner at my request...the reason being is my grandson likes to listen when he comes over. And I don't want any accidental transmissions...
K6HOM
« Reply #40 on: June 27, 2012, 01:39:08 PM »
Previously, I had posted:
Icom R7100 (VHF/UHF)
Uniden BCD998T (Digital Trunking)
Drake R8A (LW)
Icom 756Pro (Everything else)
Also have a Kiwa R75, but mine is not as good as the R8A for LW or the 756Pro's DSP filtering for BCB/HF
After two months of listening, I now use a FlexRadio 5000A in place of the Icom 756Pro for 0.540-50 MHz. Great S-AM mode, the best filtering that I have used, wonderful audio quality, and the panadapter visual tuning is a treat. No problems getting this to work on my 3 y.o. PC (Intel Core 2-2.6 GHz, 4 GB DDR2), took all of 20 minutes.  I bought Flex's recommended firewire card after reading that many connection issues come from incompatible firewire cards.
Best Wishes,
Rick
K5TED
« Reply #41 on: July 01, 2012, 09:15:58 PM »
Icom PCR-100 w/ I5XWW 455kHz to 12kHz IF tap & WinRad, HDSDR, M0KGK, Sodira, DReaM, etc.
Icom PCR-1000
Icom PCR-1500
Icom R-71A
Flex 1500
KI4VQP
« Reply #42 on: July 01, 2012, 11:08:21 PM »
In order of use:
Yaesu FRG-7
Sony 7600G
Yaesu FT450
The frog gives me the best sound and is just fun to play with, the 7600 is a great portable, and the 450 receive with outboard speakers is pretty darn good too.
N0SYA
« Reply #43 on: July 12, 2012, 06:54:46 PM »
I really like digital filters and demod for swbc and ham sue so the old analog stuff is out.
If you have a clumsy child, you make them wear a helmet. If you have death prone children, you keep a few clones of them in your lab.
K6LO
« Reply #44 on: July 13, 2012, 05:45:02 PM »
Three cheers for the FRG-7.  I have lots of higher spec receivers, but the Frog-7 is still my SWL daily driver.
Pages: Prev 1 2 [3] 4 5 6 Next   Go Up
