Author Topic: Any Elmers in the Princeton, NJ area?  (Read 1390 times)
WB2QIG
« on: December 10, 2011, 02:36:56 PM »
Where do I start? I FINALLY got back into ham radio and received a IC-7410 for an early XMAS precent. Built a long wire antenna, hooked everything up and NOTHING. Unfortunately I have no test equipment anymore. Can I borrow someone's antenna at your QTH to see if it is me (home built dipole) or the rig? In this day & age I cannot believe it is the ICOM.
Needless to say, help would be appreciated.
Maxwell
WB2QIG
N4NYY
« Reply #1 on: December 10, 2011, 05:02:33 PM »
Check them dang fuse connectors. Someone was mentioning problems with them. I cannot fathom that a new 7410 is DOA. I can see other problems out of the box, but DOA is strange. Also, find a local radio club. They will help.
K6LCS
« Reply #2 on: December 10, 2011, 09:27:13 PM »
You have a good club in town ... might want to check 'em out -
http://www.w2qw.org/
Clint, K6LCS
Clint Bradford, K6LCS
http://www.work-sat.com
KD2E
« Reply #3 on: December 11, 2011, 05:24:30 PM »
By "nothing"...do you mean no output power, no contacts, or no "dasblinkenlights"....(display).
Those matter as to what might be the bug-a-boo.
....Dave
N4CR
« Reply #4 on: December 12, 2011, 04:26:22 PM »
If that one is anything like the 746 or 756 series, the RF gain control is a squelch when turned past 12 o'clock position. So if you turned that knob all the way up, the radio might act quite dead.
73 de N4CR, Phil
