Author Topic: KenwoodTS-2000 No HF, VHF Xmit output  (Read 993 times)
N4HRA
« on: December 12, 2011, 04:15:45 AM »
My TS-2000  SN 80200109
No issues with the radio since new.
I normaly run PSK @20W.
Turned on the radio this morning, and No  HF, VHF Xmit output,
I also noticed the amp meter on the power supply shows 8 amp in
receive mode normal around 3 amps and goes to 10 amp in xmit.
If I key the the Xmit in CW I get around 2 watts with the rig set to 100W
I even tried a full reset of the radio
I jave a feelig the Driver have gone bad
Were is the best place to send my TS2000 radio for repair
Thank you
Lew
N4HRA
K6AER
« Reply #1 on: December 12, 2011, 09:15:54 PM »
Send the radio to Kenwood but before you do that do you have the  corrrect antenna port selected?
N4HRA
« Reply #2 on: December 13, 2011, 05:08:26 AM »
yes the correct antenna port was selected, the power should not be showing 8 amps in recive mode plus the VHF side also does not work, no issue with the 440
Lew
