Author Topic: ICOM IC-756 (Non Pro) Roofing filter?.  (Read 9085 times)
ZS5WC
« on: December 16, 2011, 01:50:39 AM »
 Huh
Are there any roofing filter mods available for the IC-756?.
I checked Inrad but did not see any available there.
73 de William
ZS4L / ZS5WC
K8GU
« Reply #1 on: December 16, 2011, 06:07:08 AM »
If Inrad doesn't have one, it's pretty unlikely.
However...reading the table of Inrad "VHF Filters for Experimenters" suggests that either the IC-765 or IC-775 roofing filter mod *might* work in the IC-756 (non-PRO) because they have the same first IF.  You would have to, 1. verify the 1st IF, 2. determine the amount of gain required by the roofing filter amp, and 3. devise a way to get it into your radio.  If I was in your situation, that is how I would go about it.  Good luck!
ZS5WC
« Reply #2 on: December 16, 2011, 07:39:06 AM »
 Smiley
Thanks for the great tip Ethan!.. I will investigate the possibility. The frequencies do look the same , I did a quick check.
The problem is getting a proper match at the pint of insertion in the IF chain, in order to prevent unwanted products.
Could be an interesting project!..
73 de William
ZS4L / ZS5WC
WB4IUY
« Reply #3 on: May 02, 2013, 04:35:09 AM »
Smiley
73 de William
ZS4L / ZS5WC
Hi WIlliam,
It's been a while, just wondering if you made any headway on this?
Dave WB4IUY
www.WB4IUY.net
Dave WB4IUY
www.WB4IUY.net
ZS5WC
« Reply #4 on: May 02, 2013, 11:16:07 PM »
 Smiley
Hi Dave, I ended up not buying the IC-756, sold my TS-590s and am awaiting the arrival of my new Yaesu FTDX-3000.
Great rig by all accounts!.
73!.
