Author Topic: Wouxon KG-UVD1P no RX audio - help!  (Read 2872 times)
M6PDS
« on: December 21, 2011, 08:05:19 AM »
Hi all I'm having a problem with my newly purchased Wouxon KG-UVD1P/L (2m/4m but same specs at 70cm/2m).
Although I can be heard OK when transmitting, there's no audio output on receive (even though the green led on the top of the unit lights to indicate that there is an active signal being recieved). If I turn down squelch to zero I can hear the noise on the band, so I'm at a bit of a loss to explain what might be happening. Given the complexity (and lack of decent documentation) of the menus could I have inadvertantly set something incorrectly so that it mutes incoming signals?
Anyone with a Wouxon unit who might be able to shed any light on this?
Member of the Silverthorn Radio Club, Chingford, Essex
KG6BRG
« Reply #1 on: December 23, 2011, 03:08:57 PM »
Check menu's 15,16,17,18.
For most repeater work, only #16 should be set to PL tone.  #15, 17,and 18 should be set to off (no tone).
All else fail. Do a total reset off the radio and start over.  Cheers.
