Author Topic: TS-520 mic drive issues  (Read 1449 times)
NV1P
« on: December 23, 2011, 09:05:20 AM »
Hello,
I'm having problems with power output on sideband. The rig will put out a full 100W on CW no problem. However, when using a microphone I only get out about 10W. Even with the compressor/"DX mode" it only puts out 50W peak. The mic gain is all the way up. I've tried the Heil HC-4, a D104 with astatic element, and a 600ohm kenwood mic. All seem to drive the rig about the same. Am I missing something?
Sam
NV1P
« Reply #1 on: December 23, 2011, 10:12:55 AM »
1.  What does the ALC meter indicate when you're talking on SSB?
2.  What are you using to measure power output?
Normally with a "typical" wattmeter, SSB output should read 25-30% of CW carrier power, on voice peaks with modulation.  That can easily represent "full" output power (100W PEP from a TS-520S) simply because meters can't follow modulation.
With a true PEP reading meter (or an oscilloscope) what reads 25W on a regular meter can easily read 100W, which is the real PEP power.
But never adjust the mike gain so high that the ALC meter on the 520S indicates above mid-scale in the "ALC" range, or you'll sound terrible on the air; and cranking the gain up higher will not produce more output power.
