Author Topic: CW Software?  (Read 1375 times)
K5MYJ
« on: May 07, 2005, 01:45:35 PM »
Has anyone tried any of the software that is supposed to read CW? Does it work?
Bob Macklin
K5MYJ/7
Seattle, Wa.
"REAL RADIOS GLOW IN THE DARK"
Bob Macklin
K5MYJ
Seattle, Wa
http://novicerigroundup.com/
N8UZE
« Reply #1 on: May 08, 2005, 06:22:25 AM »
It works under certain conditions as follows:
1.  A strong incoming signal
2.  Incoming signal free from interference
3.  Incoming code must be either computer generated or from someone with a fist almost as good as that.
When these three criteria are met, they work very well.  When any one of these criteria is not met, the results are poor to unuseable.
K5MYJ
« Reply #2 on: May 08, 2005, 06:42:23 PM »
I have "HamScope" installed on my computer. It seems to work well on PSK and TTY.
But I have had no luck making it work on CW.If I want to talk computer to computer I would us PSK or TTY.
Since CW was included I just wanted to see if it would work.
Bob Macklin
K5MYJ/7
Seattle, Wa.
Bob Macklin
K5MYJ
Seattle, Wa
N8UZE
« Reply #3 on: May 09, 2005, 08:11:11 PM »
I've made decoders work but only under the conditions I listed.  Of course the human brain, once properly trained, can decode things that are a LONG way from ideal.
KI4CHJ
« Reply #4 on: May 19, 2005, 06:37:16 AM »
I use CWGet. It works great for me even with a low signal. It may miss a letter or two, but you can get enough out of it to copy the QSO.
