Author Topic: 600 meter band 500 Khz's allocation coming?  (Read 10569 times)
N5RWJ
« on: January 18, 2012, 02:33:02 PM »
Will you operate on this band? REF: For info,www.w5jgv.com
KB2FCV
« Reply #1 on: January 19, 2012, 11:55:00 AM »
I may be interested in trying it out. Getting on this band will certainly take some work though!
N5RWJ
« Reply #2 on: January 20, 2012, 02:43:27 PM »
Our US State Dept. has sent a proposal to Geneva,  recommendation a secondary allocation of 15 KHz' wide, for the Amateur service at 461 to 469 and 471 to 478 KHz's  in  5 channels. The Europeans proposal  is for a 8 KHz's  wide band allocation between 472 to  480. These proposals should be decided by Feb 17,012? Note:This is for 600 meters band at or around 500 khz,s.
KE4YOG
« Reply #3 on: January 20, 2012, 03:27:56 PM »
If I can either acquire or build the equipment I will try. You think a 160 meter dipole is big you havent seen nothing yet!  Grin Grin
N5RWJ
« Reply #4 on: January 21, 2012, 10:49:34 AM »
Check with www.w5jgv.com
AE6RO
« Reply #5 on: January 26, 2012, 11:42:38 AM »
Sure, why not. Probably get a base-loaded vertical and converted old Heathkit or surplus. John
