Author Topic: Yaesu/Kenpro KR400/G400's not the RC Models  (Read 3550 times)
M0DRH
« on: January 20, 2012, 04:56:16 PM »
Hello All,
I have a Kenpro KR400, it is also like the Yaesu G400 (not the RC Models with full 360 Dial),
I have the schematics, but they are very poor copies.
Can anybody confirm the O.P voltages being: 26V for the motor, and 11v for electronics?
Also anybody have an idea what current the motor takes?
I have a burnt out controller, I need to replace the transformer.
I have a transformer with 2 X 25v each rated at 2 amps each.
I can regulate one down for the electronics, that will be low current,
But the motor maybe/takes more than 2 amps??
Any help much appreciated.
Thanks for reading
73 - Dave
« Last Edit: January 24, 2012, 10:29:26 AM by M0DRH » Logged
M0DRH
« Reply #1 on: January 24, 2012, 10:30:47 AM »
Anybody out there help??
Thanks for reading
73 - Dave
Hello All,
Thanks for reading
73 - Dave
KF7CG
« Reply #2 on: January 24, 2012, 11:25:18 AM »
That sounds about correct. I have an old Kenpro rotator, I will have to check the model and find the original manual. From there maybe I can assist. I had to replace the transformer for the elctronics in mine many years back. Rest of transformer was OK.
If you can get rotation but no indicator or dial light you might have the same problem.
David
KF7CG
M0DRH
« Reply #3 on: January 24, 2012, 03:27:23 PM »
David
KF7CG
Hi David,
Thanks for the reply.
Opposite problem here, no rotation, appears to be OC transformer,
no volts on the transformer o/p windings that give the 26V? o/p.
Have tried with rotator disconnected, just to make sure.
Thanks
Dave
