Author Topic: ? on Kent TP-1  (Read 1571 times)
W4QDX
« on: November 24, 2005, 04:47:11 PM »
Hey y'all,
I've got a Kent TP-1 paddle which I love to use, but, I have to admit, the thing is plumb UGLY with all that rough-sawn looking brass. I've polished it up a bit, but I need to get it completely disassembled to do a complete job. I need to get the contact arms (if that's what you call 'em) out. I've taken all the screws out and tried(gingerly) to punch out the shafts from the bearings to no avail. It was already assembled when I got it. Perhaps it was factory assembled with permanent Loctite?
Any ideas on how/if this beast can be disassembled?
73!
Rex  W4QDX
W4QDX
« Reply #1 on: November 25, 2005, 09:27:06 AM »
                 "Never mind!"
       I found those *sneaky* little set screws!
 W4QDX
W9GB
« Reply #2 on: November 27, 2005, 08:10:52 AM »
The Kent Twin Paddle (TP-1) is one of my favorite paddles -- largely due to it finger spacing between the paddles is wider than many other paddle -- an advantage for large hands!!
RA Kent Engineers (UK) can supply and parts or answer you questions.
http://www.kent-engineers.com/
R.A. Kent TP-1 Assembly Instruction / Notes
http://www.kent-engineers.com/TWINassembly.htm
You can order spare Parts on-line for your Kent Morse keys and paddles.  Just go to the page for your Kent Key product and click on the parts link! This will give you a listing of all the parts for that product.
http://www.kent-engineers.com/twinspares.htm
My TP-1 kit was missing the Kent logo.  Arrived via Royal Mail (within a couple of days)
w9gb
W9GB
« Reply #3 on: November 27, 2005, 08:12:30 AM »
BTW, the sealed bearing block IS PREASSEMBLED.
IF you have a problem with the sealed bearing block - contact R.A. Kent - DO NOT ATTEMPT HOME REPAIR.
w9gb
K4SAV
« Reply #4 on: December 15, 2005, 04:35:37 PM »
The Kent, mechanically, is a very nice paddle, but you are correct about its appearance. I dissambled mine and did a good polish job on it. On some of the surfaces I had to use fine sandpaper to remove the saw marks. Then I used a Dremel tool and felt wheels with polishing compound.  It will take a few hours to do this. When I finished, it had a mirror like surface, much prettier.
Now you have a choice, brass will tarnish and you will have to re-polish it periodically, but this polishing job is easy, once you have a smooth surface.  Or you can spray it with a clear acrylic.  This will cause the surface to not be as shiny, but it will stay that way for a long time. I initially tested this on a couple of parts, and didn't like the appearance, so I remove the coating.
I also turned the plastic paddles up-side down.  The normal way cramps your fingers too close to the table.
Jerry, K4SAV
