Author Topic: Yaesu FT-840 To Computer  (Read 1805 times)
KB5WHX
« on: February 26, 2012, 10:13:01 AM »
Hello,
I am trying to get a list of the items needed to connect my Ft-840 to my HP desktop computer.  I do not want to work any digital modes
I simply want to control the radio from my PC (not remote control).  Please correct me if I am wrong but, I think I need the CAT cable which will run from the radio to the computer.  Since my PC does not have a RS-232 serial port I will also need a USB to RS-232 converter. Is there anything else I need (Drivers) or need to know.  The software I intend to use is Ham Radio Deluxe.
Am I correct in assuming that I do not need an interface in lieu of the fact that I am not working any digital modes?  Also, since this radio is fairly old what will I be able to control with the computer?  I am not sure this is worth the effort but I am curious.
Any information or additional  advice (where to purchase cables) which would help me link these items together would be appreciated.
Sincerely,
Steve
KB5WHX
KB6HOH
« Reply #1 on: February 26, 2012, 01:13:19 PM »
Hi Steve,
            Steve here, KB6HOH in the SF Bay Area. Boy I have never had so much problem trying to download a User Manual until now! Anyway you are correct, if you don't have a Standard Serial Port on the PC you will need a USB to Serial Adapter. I highly recommend one from Keyspan. I use to be a Assist Tech Manager and Lead Tech for CompUSA I tested several for myself. I use one here on my Windows 7 32bit Ultimate and NO problems.
Here is a YouTube link I found for the FT-840 and HRD:
http://www.youtube.com/watch?v=a4JbqdmtIZk
Also I pulled this off the HRD Fourms:
http://forums.hrdsoftwarellc.com/showthread.php?23085-FT-840-connection-problem
Good Luck!
                                  73 de Steve KB6HOH
K3AN
« Reply #2 on: February 26, 2012, 06:57:34 PM »
If you don't already have the CAT cable then I would suggest buying a USB to CAT cable. No physical serial port or USB to serial adapter cable needed. The USB to CAT cable comes with a CD containing a driver that creates a virtual serial port that you can see when you open Device Manager on your PC.
Here's an example from Amazon: http://www.amazon.com/FT-100-FT-817-Chipset-Supports-Windows/dp/B0041LNISK
Ebay has numerous sources for even cheaper ones. Just search "CAT to USB" in the Electronics section.
W0GLB
« Reply #3 on: February 27, 2012, 11:44:40 AM »
Hi Steve - I recommend you check out this site:  http://www.g4zlp.co.uk/unified/YaesuCAT.shtml
I have been using one of his cables for my FT-840 for five or six years now, and it has performed flawlessly.  Shipping is VERY fast, even though he is overseas.
W0GLB Gordon
