Author Topic: Butane Soldering irons, like Portasol?  (Read 12193 times)
KC2MMI
« on: March 17, 2012, 07:19:07 PM »
I bought a Portasol some years ago because I needed to make a mess of simple solder repairs withtou AC power around. The Portasol worked very nicely, given the amount of heat it made, and as long as you didn't try to use it in freezing weather or high wind.
Then I found the catalytic material in the tips wore out, way before I would have expected.
Tried a couple of new tips, same thing, they just don't last very long despite the best Ronson butane fuel sold for the tool.
So, has anyone had better experience with a better brand? Different tool? Apparently the Portasol is actually made overseas, and neither the maker nor the importer really gives a damn, they dont even answer email inquiries.
I still find soldering without AC very convenient and sometimes necessary, I'd just like a better tool to do the job with.
--Jared
W5FYI
« Reply #1 on: March 17, 2012, 11:49:54 PM »
I, too, had a Portasol, but when it developed a leak in its butane tank, I replaced it with a Radio Shack model. The page at http://www.radioshack.com/search/index.jsp?kwCatId=&kw=butane%20soldering&origkw=butane+soldering&sr=1 shows that even Weller has butane irons on the market, and your luck with their catalytic heating elements might be somewhat better. GL
NA4IT
« Reply #2 on: March 18, 2012, 04:41:52 AM »
I have one of the older Weller pen type units. It does OK. I have used it mainly outside working on antennas, as the torch for soldering wire splices, and as the iron, soldering PL259 center pins.
KK4GER
« Reply #3 on: March 18, 2012, 06:35:20 AM »
This is a nice unit and their support is great.  I inquired at www.pro-iroda.com for spare parts and they sent them to me at NC:
http://www.pro-iroda.com/Pro150K.htm
Also, for the price, this set is great:
http://www.eastwood.com/9-in-1-cordless-soldering-iron-torch-and-blower.html
K0JEG
« Reply #4 on: March 18, 2012, 11:51:37 AM »
I bought an Ultratorch UT-100si a few years ago. It hasn't let me down in any of that time (other than not wanting to light on the first click of the igniter at 9000+ feet, but eventually it did go). Kind of pricey though:
http://www.masterappliance.com/heat-tool-products/butane-powered/ultratorches/ultratorch-ut-100si
KC2MMI
« Reply #5 on: March 18, 2012, 05:59:58 PM »
As best I can tell, the Wellers are all flame torches that heat the underside of the tip. As are the SolderPro, which should take catalyst probles out of the mix I guess. If I went for Solderpro, I'd avoid the top models that use special fuel cells--one more thing that won't be in stock when you need it. Surely, Ronson's butane can't be all THAT contaminated?
Has anyone else got thoughts on whether I've just had a bad run of catalysts, or if catalytic tips like Portasol's are just, ah, a comment on irish engineering?
W5FYI
« Reply #6 on: March 20, 2012, 01:16:20 PM »
They tell us that leaded gasoline (tetraethyl lead) would ruin catalytic converters in cars--the lead contaminates the platinum in them. Could you have gotten a little solder splatter onto your iron's catalytic element?  Just a thought....
K0EKL
« Reply #7 on: March 22, 2012, 02:49:16 PM »
Another vote for the Ultratorch UT-100. Works great, easy to get replacment parts if they are needed, and it puts out as much or as little heat as needed.
KC2MMI
« Reply #8 on: June 06, 2012, 02:18:25 PM »
Lead contamination, interesting concept. If it could go uphill, pass the filter screen, and dose the catalyst element well enough to ruin it...interesting concept but I'd hope to see a "use only with lead free solder" sticker on there if that applied. Lead is sprayed in engine exhaust, this would be a much less likely path.
