Author Topic: Watch the band edges  (Read 17699 times)
K8AC
« on: March 25, 2012, 01:32:28 PM »
I was amazed this morning listening to VK7ZX sitting on 7.126010 running US stations at the rate of about 100 per hour.  Transmitting on that frequency on LSB results in radiating quite a bit of sideband power well below the 7.125 limit for US stations.  The transceiver frequency reads the carrier frequency and a bit more care needs to be exercised when operating LSB near a bottom band edge or USB near the top edge.
KG4RUL
« Reply #1 on: March 26, 2012, 10:32:30 AM »
I don not know what they teach Hams in other countries but, the Technician Class exam has this question (hint, the first answer is correct):
T1B09: Why should you not set your transmit frequency to be exactly at the edge of an amateur band or sub-band?
All of these choices are correct
To allow for calibration error in the transmitter frequency display
So that modulation sidebands do not extend beyond the band edge
To allow for transmitter frequency drift
K8AC
« Reply #2 on: March 26, 2012, 01:18:13 PM »
But - you could miss that question and still pass the test!  And, just what is meant by "exactly at the edge..."?  A reasonable person could say that 7.126010 isn't exactly at the edge.  Just what the lower limit is in this case depends upon one's voice characteristics, how high you have the processor set, etc.  In some cases, 3 KHz might be too close, but in nearly all cases, just over 1 KHz assures that a significant portion of the sideband is outside the limit.
K1ZJH
« Reply #3 on: April 06, 2012, 01:57:51 PM »
Not for lower sideband on 40 or 75 meters on the low end of the band!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
W9KDX
« Reply #4 on: April 07, 2012, 11:54:47 AM »
I am grateful that the N. Cook Islands had the common sense to transmit on the absolute low end of 40 meters, but were listening 10 up.  Never would have made the contact otherwise.
Sam
W9KDX
K6OK
« Reply #5 on: April 09, 2012, 11:47:57 AM »
Is this like petty theft vs. grand theft?  7.126 LSB is indeed poor practice because the sideband spills into the CW segment. Ultimately though it's hams interfering with other hams, so there's no damage to the real world. This is not as serious as operating at 14.349 USB because there the sideband spills outside of the amateur band and could interfere with other non-amateur services.
K8AC
« Reply #6 on: April 09, 2012, 12:13:15 PM »
Smells like a troll, but deserves a response.  Both petty theft and grand theft are crimes.  The only difference is the dollar value involved.  Operating LSB on 7.126 is not just poor practice - it's a violation of the rules we operate under.  It's not up to us to judge which rules we choose to follow, nor decide which violations might cause the greatest problems.  It's a good idea for everyone to follow the rules as they're laid out.  I'll wager that every one of those who responded on 7.126 did so out of ignorance, not because he thought he could get away with a petty violation.  My post was an attempt to elighten some who either were not aware of the fact that 7.125 is the lower band edge for SSB operation in the USA, or that their LSB extends far below the carrier frequecy their display reads.
K6OK
« Reply #7 on: April 10, 2012, 11:50:25 AM »
I don't think I smell like a troll -- I do use deodorant every day  Cheesy  I was serious in my comments. You're right, both 7.126 LSB and 14.349 USB are rules violations and both are wrong. I was just pointing out, for discussion purposes, that the consequences of one is more serious than the other.
KC9TNH
« Reply #8 on: April 11, 2012, 04:16:42 AM »
Your post was appreciated. From what you describe there wasn't spillage; the station was flat-out in the wrong area according to his/her own band plan as well. Doesn't usually affect all but up in "da Nortland" it can be a bit irritating to get one's CW QSO stomped on by a SSB ragchew in the wheelhouse of what seems to be a well-known CW area in the US band plan (7050 etc) but perfectly in line with the RAC plan for voice. Your example seems to be outright ignorance by the station, the CW/SSB conflict thing is a problem at a higher level. When that happened recently I did a couple minutes research fortunately before keying up & learned something as a result.
Your post was a good reminder for all, thanks.
Wes -KC9TNH
"Don't get treed by a chihuahua." - Pete
K0SPN
« Reply #9 on: April 25, 2012, 11:25:54 PM »
American amateurs are responsible for operating within their legal privileges just like the VK station was responsible for operating within their own privileges.
Was it the best place for the VK to choose to try operating Americans?  Obviously not, but they have no responsibility to police Americans and make sure said Americans are obeying their own rules.
I don't know the VK rules and allocations, so I can't comment on the legality of the operations on that particular frequency.
VK4NEF
« Reply #10 on: September 17, 2012, 03:34:48 AM »
I know its a bit late, here is the Australian (VK) Band Plan for 40 Metre.
40 Metre Band – All licence classes
7.000 - 7.300 CW
7.030 - 7.040 Digital data modes (Note 2)
7.040 - 7.300 SSB
7.075 WICEN frequency
7.110 IARU Region III emergency centre frequency
7.130 - 7.150 WIA news transmissions
Note 2: Modes
"Digital Data Modes" includes all modes such as RTTY, packet and Amtor, using FSK or PSK and with
bandwidths up to 2 kHz. The SSB segment can also be used for digital voice modes and image transmission
modes such as SSTV or Fax, using bandwidths up to 4 kHz, or for AM.
For a pdf of Australian Bandplans, go to this link:http://www.wia.org.au/members/bandplans/about/ then click on Bandplan Data (left hand side).
Myself when trying to work stateside from VK I try to be around 7.170 MHz or higher.
Now 80 Metre DX Window is a different kettle of fish in VK
3.776 - 3.800 DX Window SSB and CW.
NOTE: DX WINDOW
Emissions must not extend below 3776 kHz. Therefore when using LSB, the suppressed carrier frequency
should be no lower than 3779 kHz.
Also the Oceania DX Contest is being held on these dates,
PH - The first full weekend in October each year from 0800 UTC Saturday to 0800 UTC Sunday
CW - The second full weekend in October each year from 0800 UTC Saturday to 0800 UTC Sunday
Log deadline for PH and CW logs - 28 days after the end of the CW contest.
For more info go to the web page: http://www.oceaniadxcontest.com/
Regards
Eric
ZENKI
« Reply #11 on: September 18, 2012, 02:10:12 AM »
Hopefully you dont have the ESSB idiots in VK. Its so ridiculous hearing  6khz wide ESSB idiots with  bassy audio trying to work DX with their selfish bandwidth practices. The DX window is so narrow and is expressly a DX window. Why these ESSB stations want to take out the DX window with excessive IMD/splatter and excessive occupied bandwidth is beyond belief.  If some of these ESSB stations operated in VK they could not really operate anywhere in the VK DX window because their signals are so wide.
I always use 1.5 X TX Audio bandwidth to be safe  that  allows for any IMD splash, you can never get into trouble doing this.  I use 2.4khz wide audio at all times  and my signal has very low IMD.
NOTE: DX WINDOW
Regards
Eric
[/quote]
W8JI
« Reply #12 on: October 05, 2012, 08:09:02 AM »
K8AC's post was accurate and perfectly correct. The USA stations were transmitting out of the band.
I'm sometimes amazed at how people no longer respect the band edge, or perhaps are so stupid they do not know what the band edge is.
The law is we cannot have modulation products extend out of the authorized band or segment available to the operator. Even for the Extra class of license in the USA, this means NOTHING can appear below 7.125 MHz. Zero detectable emissions from phone can extend below 7.125.
This means, for exceptionally clean LSB transmitters with a highest modulating audio frequency of 3 kHz, the suppressed carrier frequency would have to be above 7.128. In reality, with a good antenna and/or higher power, even 7.130 is pushing it for most rigs. Rigs just aren't that clean and, with a strong signal, it is easy to have products above background noise.
Years ago I used to listen to some people in the eastern USA meeting every day on 7.200 kHz LSB when the phone band used to only go to 7.200.  One day they stopped showing up, and I found them up on 7.205 complaining that they all received FCC "show cause" notices.
Too bad the FCC doesn't still do this.
73 Tom
KB5ZSM
« Reply #13 on: November 14, 2012, 11:47:08 PM »
I can see one other cause for the out of band problem. Excitement!!! Even I was guilty of it once (not being out of band, BUT!). When I was a new general class I heard a DX station with a pile-up on 14,215. I got excited and didn't even think about it till after the fact and I did make contact on the second call but I was out of my band privilege's. As I said, it never occurred to me till it was all done and over with. I felt bad (but good for the DX contact). Since then it has been something I pay better attention too. Just got caught-up in the action and didn't think!
WS4E
« Reply #14 on: November 15, 2012, 12:46:44 PM »
YOU KNOW... in this day and age with all the CPU POWER in the modern rigs, it would not be anything for them to put in automatic band edges that account for what mode your in...  I mean REALLY how hard would it be to have a little more intelligence for the radio to know that "OK, the absolute edge is 14350, if the radio is in USB mode, then don't allow transmit above 14347 instead".
I mean its a simple bit of automatic MATH for the radio to do.
Right now they just are dump and do simple rules of no xmit above 14350 etc..
